Extending the antennas on router.
  • Hornnumb2
    • Feb 2011
    • 218
    My router has 4 antennas, could I run some rg6 with BNC connectors and put the antenna say 30 feet away to get better coverage through my home? Thanks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Extending the antennas on router.
    I generally just get a commercial AP (unifi) with extended range and disable the radio on the router
    Wifi RF can be tricky sometimes
    • redwire
      • 3912
      Coax cable is terrible at WiFi frequencies, for losses. You want the shortest coax run possible to an antenna. Otherwise you'd lose all the gain from a big antenna. RG-6 is not good for microwave frequencies either. RG-6 30' at 2.4GHZ is -5dB or about 2/3 less power.
      I would look at getting higher gain antennas and connecting those to the router, you'd have to know if they have MMCX plugs or what on the circuit board. Some don't even have real antennas, they are fake and the antenna is on the PC board.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        As I said, fucking with wifi antennas is not an easy thing. Run an ethernet cable to the middle of your area and put/mount this there
        https://store.ui.com/products/u6-lr-us
        Follow instructions, plug in the POE and you have a good coverage AP with wifi6 (and of course AC and 2.4ghz and all that jaz
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          How about some fiber optic cable?
          • petehall347
            • Jan 2015
            • 4451
            • United Kingdom
            4 antennas sort of says you should have more routers . think its called mesh or something .
            • redwire
              • 3912
              First look for barriers to WiFi signals - any metal, concrete, wire mesh lath and plaster, anything with water including plants and trees - greatly block the signal.
              Second, is if the neighborhood is WiFi busy, such as apartment blocks with dozens of routers, you will find more time is spent by the router changing channels than actually sending your data. Or kids streaming videos and games hogging bandwidth. You might go into the router configuration menus and check for monkey business, kids get the router password and give themselves full speed but not for ma and pa.
              Ethernet is king, copper wire/fibre optic cable faster than radio so if you can hardwire up to the router - do it.
              Routers also have capacitor failures, and in the 12VDC power adapter as well, so if you are having issues it might be time to recap.
              I've also had DoS attacks slow things down, all supposedly from Apple.com not sure what their security problem is.
              It's best to get into the router configuration menu, look at signal strengths etc. or if other people can access the network (just change the passwords).
              • double_DD
                Why does my ISP router hate my "homemade" power supply??
                by double_DD
                It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                07-12-2025, 03:09 AM
              • shadow666
                Router Xiaomi M4A Gigabit
                by shadow666
                hello
                i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                Mi Router 4A Gigabit Edition
                ROM CHIP is 16 MB
                i attached picture of motherboard​...
                11-30-2024, 03:49 PM
              • EasyGoing1
                UPNP, "Standards" and hardware that implements it
                by EasyGoing1
                I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                So I decided to implement UPNP...
                07-16-2022, 07:12 PM
              • shadow666
                need dump Mi Router 4A Gigabit - M43 R0101
                by shadow666
                hello
                i have a Mi Router 4A Gigabit
                Motherboard : M43 R0101
                i need dump and rom is 16 MB
                thanks
                10-20-2025, 08:20 AM
              • hinisa
                Xiaomi router freezes at boot after re-capping
                by hinisa
                I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                07-08-2023, 05:58 AM
