XP fun!
    • 31291
    XP fun!
    http://news.bbc.co.uk/1/hi/technology/10473495.stm
    and as one guy on another forum put it:
    Maybe the title to this article should be: "Hackers working out of Microsoft's own offices target Microsoft Windows XP support system so that people happily using XP will be forced to upgrade to Windows Vista or Windows 7"
  • Krankshaft
    • Jan 2007
    • 2328
    Re: XP fun!
    There's no way they'd get through a routers hardware firewall. I'm thinking these PCs are directly connected.
    In which case if you don't have any type of firewall protection this would be the least of your worries.
    • NxB
      • Feb 2009
      • 1595
      Re: XP fun!
      Not the first exploit and it won't be the last.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: XP fun!
        hence why i use windows only when i must.
        sigpic
        (Insert witty quote here)
        • Scenic
          o.O
          • Sep 2007
          • 2642
          Re: XP fun!
          indeed. my own router instantly stops responding to the attacking IP if someone tries to connect/scan/flood my connection..
          tried it myself from my bro's connection. had a routed-through HTTP server running at home and did a portscan from my bro's place. after the 5th port being scanned within a couple secs, i couldn't access the HTTP server anymore. my router completely blocked the access from my bro's IP..
          all that also shows up in the router's text-log. you'd be suprised when you see how many times ppl try to do portscans and (ping-)floods..
          only problem is that i have to restart the router every now and then cause it's running out of memory for the text log
          • notallbad
            LG 55LM6200-TA country group/Area option
            by notallbad
            This is a 2012 LG TV so aware full functionality of the smart functions/apps will be limited however currently unable to get the LG Smart Store.
            Youtube, Netflix and LG Smart store icons briefly appear in the apps list but then automatically disappear after doing 'Initialisation of Premium' via the standard menu, I'm guessing this is due to the Country/Area group its set to is wrong for the UK.
            Unable to change the country group, Area option can be changed which alters the country group but none make any difference. So believe its the country group that needs changing....
            10-20-2024, 11:16 AM
          • Hondaman
            Hardware firewall to block ad servers?
            by Hondaman
            I found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
            The trick, apparently, is to "assign IP address lists from sites like I-blocklist...
            02-05-2025, 05:04 AM
          • juergenb
            Sophos XG86w Firewall forgets the date and time as well as the DMI environment variables after power cycle
            by juergenb
            I have a small Sophos XG86w firewall here, which is still working so far. But there is a problem with the BIOS and the DMI environment variables.
            The hardware forgets the date and time after a reboot or a power failure.
            The DMI environment variables are also reset to default values.
            I have now tried 2 different batteries (CR2032).
            I reset the DMI vars via an EFI shell and with AMIDEEFI64 (v5.21.0057).
            However, after a reboot or a power cycle, these values are reset again.
            It is an Apollo Lake platform with an Intel...
            10-08-2024, 04:19 AM
            Elite Group (ECS) Motherboard H61H2-CM REV 1.0 Board View
            Elite Group (ECS) Motherboard H61H2-CM REV 1.0 Board View...
            10-03-2024, 06:31 AM
          • Hornnumb2
            Home routers
            by Hornnumb2
            Is it just me or does it seem like the routers just dont last anymore. It seems like about 1 1/2 years mine starts dropping signal and losing connections. I am not buying the cheapest but middle of the road around $100. Any suggestions for one that will last? Thanks Michael
            07-01-2024, 07:36 AM
