sister withdraw
    sister withdraw
    Long story short, My sister needed a new PC. The one that she had she gave up to her... ummm... husband??? Lets just say that there are problems between the two of them.. major problems if you get my drift..
    In any case, I bought some parts to build a new tower for her.. She gave up the tower to her soon to be ex, but still has every thing else..
    I went kinda cheap on hers so no major critics on the parts.. Hey its not for me and she is getting it free.. I am not putting a lot of money into it.. and I figure that if she wants, she can spend the money to upgrade it later with things like a PCI Express vid card or more ram or... you get the idea.. here is what i put into hers..
    ECS G41T-M(2.0) LGA 775 Intel G41 Micro ATX Intel Motherboard (retail)
    Intel Pentium E5300 Wolfdale 2.6GHz 2MB Cache 775 65W Dual-Core Processor (Retail)
    Rosewill R103A Black Steel ATX Mid Tower Case w 350W Power Supply
    Asus DRW-24B1ST/BLK/B/AS black dvd/cd burner OEM
    Rendition by Crucial 1GB DDR2 800 (PC2 6400) ram (yes, just one stick)
    Western Digital WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb drive OEM w 3 year warranty
    total price $222.89 w shipping
    I am thinking about doing a duel boot of XP and 7 for her so she has backwards and forward capability for different things. Ill probably partition it in half or 2 partitions of 250 gig each. and yes i will add case fans to it.
    no matter what way you look at it, it is better then the 1.1 Ghz machine that she is borrowing from me right now.. ETA June 4th.. All i can say is she better appreciate this..
    Ok.. now here is the kicker.. I told her last week that I already found something for her birthday, which is in July.. I just wont tell her what it is.. She has been pestering my mom to try and find out what it is.. Its driver her nuts.. Well the case that I got her looks exactly like the case that she borrowed from me. What I am thinking about doing is just telling her that I need to do something to the PC and to bring it in next time she comes in town. She lives 2 hours away. And she wont question what I need to do. She is one of those types that is book smart, just don't try to talk anything electronically to her. After she brings it in, transfer all the stuff to the new PC, not tell her that i did it and then send it back. Then tell her happy birthday, that all you get. maker her think i am just giving her this old 1 gig PC and since both cases look identical, she wont know that it is a completely new PC. Just have to make sure that she does not see the new one..
    So what do you think??
    Re: sister withdraw
    Don't do the dual boot, just install the XP Mode for Windows 7. Unless she needs anything with video acceleration, it should work fine. http://www.microsoft.com/windows/vir.../download.aspx
      Re: sister withdraw
      1gb is not enough memory.
        Re: sister withdraw
        The reason that i was thinking about doing the duel boot was this way when she starts buying stuff that does not support XP and only 7, It is an easy switch and do not have to worry about her bringing the PC back to have it reinstalled. saves me work later. and one other thing.. my sister is not always the most electronically inclined person around.. that goes with OS's too,. She is used to XP. I dont need to hear from her time after time trying to get used to 7. This way she does it at her own speed and a lot less hassle for me..
        as for the 1 gig ram. that depends on what you do. IF all you do is play small online games, read email and browse the net, then that is fine to start off. Like i said, it is 1 stick so she can upgrade when she gets the money. I am trying to keep my costs down while still giving her something somewhat decent to start off with. I could have went cheaper with a smaller hard drive, less ram, slower processor, or even just a basic ROM instead of a burner, etc. but i already put that extra into it for her. For what i have coming in, I think I am pretty dang nice for doing this much.
          Re: sister withdraw
          If she disables the Aero interface, she can drop the idling RAM consumption from a gig down to about 700mb. That 300mb will let her surf, etc, without hitting the paging file.
            Re: sister withdraw
            Actually 7 can go way below 700 megs idle on a 1 Gig machine. It realizes when resources are low and adjusts accordingly. I have it on a couple of machines with 1 gig and it uses about 400 megs idle. With some tweeking you can get that down lower. I've even tried on 512 MB just to see what it does, it went down to just over 200 MB idle.
            Also, if you have a real video card then Aero has a very minimal impact on memory. 7 doesn't buffer windows in system RAM like Vista does, everything is put in the video RAM.
              Re: sister withdraw
              I loaded windows 7 on my laptop. It ran at about 1 gig ram with my antivirus running plus the basics loaded (flash, shockwave, java, etc.). Also dont forget that even if you have 4 gigs of ram and are only using 1 gig, it still loads stuff into the pagefile by default.. all the stuff that it sees loaded but estimates that are not going to be used. that can be a couple hundred megs so it is not like the 1 gig is really maxing out the system bad. that is why i did not want to go with under 1 gig.
              I once remember my friend got a new PC. It came with vista multimedia edition (or whatever it is called) and only had 512 MB ram in it plus had a integrated video card on top of it.. that ran like crap.. My first thought was shat idiot decided that it only needed 512..
                Re: sister withdraw
                Hope it works out. She'll see a big difference.
                I think I would have spent the extra 15 bucks for a stick of 2 Gigs of ram especially if she does more than email and web surfing.
                  Re: sister withdraw
                  I know that she does MS office stuff, email, online games (small ones) and views pics (digital camera). Beyond that I dont think much else.. One thing I should have also said.. I live off of disability which is not much a month.. She has kids but works for the state in a prison as a teacher.. the main reason that she is in the situation that she is in now is a combination of her husband (soon to be ex) and stupid decisions on her own end (does not have her car paid off and takes out a new loan to get an almost brand new car) etc. So the way that I look at it, she has a heck of a lot more coming in then I do. I am doing this to help her out right now, but she can pay for any additional upgrades..
                  so yes.. I could have paid the extra 15 for 2 gigs of ram, but then again i could have gotten a decent video card for it for 35 after rebate too and spent the extra 10 or 15 so she has 2 roms and an extra 10 so she has a memory card reader for her digital camera and.. well you get the idea.. but every "well.. i could.." leads up to more money and then next thing you know, you are looking at $200 later.. Like I said.. she makes multiple times more then me a month.. she can pay for that stuff herself.. she is just dang lucky I am being this nice..
                  I think you can now see why I stopped where I did.. Not to mention, My fastest PC has a single core 2.5 gig AMD athlon processor, so what I am giving her is sooooooo much faster and bigger then what I even have.. Did I mention just HOW lucky she is that I am being nice????
                    Re: sister withdraw
                    and the joke about that, is that a 1gig athlon or p3 with 512-1g of ram running Linux and open-office would do all that without any problem.
                    microsoft doesnt specialise in software, they specialise in marketing.
                    most people dont realise that they are doing the same stuff now on a quad-core with 4 gig of ram, that they probably did with a 486,
                    the only real difference is the eye-candy.
                      Re: sister withdraw
                      I cant argue with that.... and if that PC that she is using was hers then i would probably not say much. The thing is her PC went to her soon to be ex and the way that I was looking at it, she has 3 kids.. 14 (boy) 12 and 9 (both girls) and if they do decide to want to play something on it other then really cheap games, this would give them the option to. I dont foresee her getting a new PC for quite a few years after getting this one so it will last her for a long time. that is a good thing.
                      I forgot to add.. the PC that she is using now is a 1.1 gig but also has 1.5 gigs of ram and a Nvidia 6200 series vid card.. but like i said, that is what she is borrowing from me.
                      you know.. after building this new system, by speed, my systems seem so old, but by looking inside, it just looks like something is really missing in there.. I am used to PC's that have a bunch of stuff in them. Sata cables take up so much less room, no to mention, no expansion cards and a mico board. just really looks like something is missing.
                      and I did get it. It is up and running. Did a triple partition. 200 for XP, 200 for 7, and the rest for storing files (she had that on her last PC but not sure if it was her choice or someone else's).
                        Re: sister withdraw
                        Maybe 1 GB is good enough memory!
                        avatar
                          Re: sister withdraw
                          Go 2GB or more and use windows 7 home permium 64 bit.
                          That what I have now on my current home PC (2 years old E5200 stuff). Had to do this as windows XP failed in a way I could not access the stuff with keyboard or mouse. Pointer is frozen.
                          Also I could not get firefox bookmarks to transfer to my new windows 7 install from old that I got from firefox's bookmarks while in XP home safe mode. Firefox is all current version.
                          Help?
                          Cheers, Wizard
                            Re: sister withdraw
                            Well, the PC is gone.. I decided to tell her about the PC while she was here.. I told her that I did some stuff to make it faster.. She was like "WOW" that really did make it faster.. what did you do? whatever you did, it worked... while still completely clueless that it was a completely different PC.. It was at that point that i told here what i did.. She told me to get another 1 gig stick and put it in. I got one off ebay for about $16 and she said to get a second drive for it too. I also added a Nvidia 7200GS w 256MB ram on it, video card so no built in video card (got it for $10 off ebay). She gave me the money for both. I also ordered (ebay from china) a 3.5" memory card reader that i will put in when it comes in too (about $2.80). She is completely happy with it. well, i did my good dead for the year..
                            Help?
                            Cheers, Wizard
                            All you have to do is copy the contents of the bookmarksbackup folder from one to the other. there should be about a half dozen files with the extension .json .... here are the paths
                            XP:
                            "root drive"\Documents and Settings\"user name"\Application Data\Mozilla\Firefox\Profiles\x0x9xemz.default\bookmarkbackups
                            The "x0x9xemz.default" part (XP) and "9xoy9vhs.default" part (windows 7) may very
                            7:
                            "root drive"\Users\"user name"\AppData\Roaming\Mozilla\Firefox\Profiles\9xoy9vhs.default\bookmarkbackups
                            On XP and 7, make sure that view hidden files and folders is on..
                            after that start up firefox, click on "bookmarks", then "organize bookmarks" in the submenu, "import and backup" at the top of the box that just opened and then "restore" in the submenu and choose one of the dates in the list that comes in the submenu.
                            you should then have all you bookmarks back.
                              Re: sister withdraw
                              remember that xp mode is only for win7 professional or above. you can get it to work with home, with some pita hacking though
                                Re: sister withdraw
                                oh no... not a card reader from china. plan on buying a new one within the year... they are the WORST quality... they ones branded DYNEX that best-buy used to sell were nice, my main rig has one in it, still chugging a long to this day...
                                sigpic
                                (Insert witty quote here)
                                  Re: sister withdraw
                                  most of the ones being sold from the US are the same as the ones from china.. just a price mark up.. at least on ebay that is true.. and if it dies after a year, for less then $3, I am not out much.
                                  I do agree that a lot of the stuff that comes from china is a piece of junk... but lets be honest, where did you say that the dynex one was made?? China anyone??? and i have had dynex stuff before before. They are very cheaply made things. I had a network switch. That almost felt like it would fall apart or break if bumped. trust me when i say, it had the worst quality of a case that I had ever seen in my life. and if the quality of the outside was that bad, then the inside could not be much better. Do a search on dynex keyboards.. see how many complaints there are about them not working. I have never seen a dynex brand anything that I thought was even halfway decent made.. sorry but i stay away from them.
                                  as for that switch.. only used it a short time and then it went into a box for parts. so for long term use, i can not say if they do last. the only reason i got that one was that my last switch died and it was all i could afford at that moment. I went out and got a linksys switch a short time later. that one feels made about 100 times better.
                                  I think that the dynex brand was probably made and designed by geeksquad. they are pretty close to equal. I have never heard anyone that went to geeksquad for PC work that left happy.. If you just want a stick of ram installed, you are fine.. just dont ask them to do anything harder then that.
                                    Re: sister withdraw
                                    when you get it replace all the caps through the entire system for $20 to make sure it lasts more than 3 years?
                                    j/k
                                    seriously, 1gb ram is not enough for anything
                                    chugalugahug pzerrrhph!
                                    waiting....
                                    well yeah i remember i had whopping 8mb ram on a 286 33mhz once
                                    man i was blazing fast learning my ibm dos
                                      Re: sister withdraw
                                      Women initiate 75% of divorces in the US.
                                      Oh yea, and take a case without the PSU. The one the Rosewill will come with will be garbage.
                                      "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
                                      -Leonid Brezhnev (On the Yom Kippur War)
                                        Re: sister withdraw
                                        ditto on the rosewill psu comment^. too crappy to power your computer (well), too light for a doorstop.
                                        sigpic
