hard drive setting - change the mbr partition of hard drive to ntfs
  • Saihah Fakhriyah
    • Nov 2021
    • 9
    • united kingdom
    how to change the mbr partition of hard drive to ntfs?
    • 31204
    Re: hard drive setting - change the mbr partition of hard drive to ntfs
    you mean without losing the content? or just wiping the partition?
    • federalhouse
      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
      by federalhouse
      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
      **Background:**
      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
      **What I've Tried So Far:**
      1. I accessed
      08-01-2024, 07:03 PM
    • tmcw
      PC case - Hard drive rails
      by tmcw
      A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
      So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
      I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
      Now, the case is a CiT Gaming Case, and...
      05-22-2022, 12:04 PM
    • madura2010
      DAY11AM6E0 hard disk drive and optical disk drive not detected
      by madura2010
      Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
      i checked the connectivity of ribbon=good communication with hard and motherboard
      changed hard disk and checked=3f0 error persist
      sata power=+5v available
      Then checked data capacitors=all good
      Then checked data lines path connectivity to pch=all good
      reflashed...
      03-12-2023, 09:09 AM
    • ash91
      Hp pavilion 15 not detect hard drive
      by ash91
      Hello gentelmen .... this is my first post and sorry for my bad english,
      so my proplem is my laptop keep losing hard drive even if i but the
      hard disk in the cady (the box that can replace the dvd rom with hard disk)
      when i turn the laptop on the massage that said no boot media found pop on
      the hard disk is fine and to be sure i try another hard
      i also update my bios to the last update
      the 5 volt is present on the hard connector on the motherboard
      the dvd rom work fine when i but a windows dvd in it
      also when i boot from flash...
      06-07-2023, 01:45 PM
    • karto95
      Repairing a Seagate hard drive with damaged logic board
      by karto95
      I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
      I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
      If anyone has any suggestions or experience with this...
      03-21-2023, 04:05 AM
