Unidentifiable
  • keyboardcowboy
    • Apr 2006
    • 73
    Unidentifiable
    Sorry for posting in the wrong section
    can someone help in identifying this transistor type thing, it has no markings on it or on the pcb from where it came, its fried (short on all pins)..
    came from a NOKIA AC-4E charger
    • 31144
    Re: Unidentifiable
    impossible to id from the shape.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Unidentifiable
      idk either. i fried one trying to add a heatsink (in a mad catz 3v car adapter)... they overheat quite often...
      sigpic
      (Insert witty quote here)
      • NxB
        • Feb 2009
        • 1595
        Re: Unidentifiable
        My guess is a voltage regulator since it came from a charger. Without a pic of the circuit or any markings there is no way to say for sure.
          • 31144
          Re: Unidentifiable
          most nokia stuff is switching, not analog though.
          • keyboardcowboy
            • Apr 2006
            • 73
            Re: Unidentifiable
            Here's the Original circuit
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: Unidentifiable
              likely any npn power transistor will do.
              its a crude simple switcher.
              • keyboardcowboy
                • Apr 2006
                • 73
                Re: Unidentifiable
                Any recommendation?
                The charger is rated as 5v/890mA
                • stevo1210
                  • Oct 2006
                  • 4156
                  Re: Unidentifiable
                  Um. I don't think a new charger would cost much...?
                  • keyboardcowboy
                    • Apr 2006
                    • 73
                    Re: Unidentifiable
                    Well its not about the price, this charger was just lying useless, just wanted to get some experience in repairing stuff
                    • Wizard
                      • Mar 2008
                      • 2296
                      Re: Unidentifiable
                      Remembered the design like in ultrasonic circuit just one transistor and oscillator using R & C circuit in 60 Hz bursts in KHz range (around 30-50KHz). Use a NPN with strong voltage tolerance and high base voltage tolerance as well. Not too critical.
                      Cheers, Wizard
                      • NxB
                        • Feb 2009
                        • 1595
                        Re: Unidentifiable
                        Open a similar charger up and see what they used.
                        • delaware74b
                          • Apr 2009
                          • 628
                          Re: Unidentifiable
                          I zoomed in on the photo on the solder side of the board and it looks as if pin #2 (center) has been partially lifted from the board.
                          Stupidity should be a crime, especially for drivers. I have NO patience for them.
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            Re: Unidentifiable
                            it may be still usable or just remove the lifted part of the trace and run a wire.
