Best Android phone?
  • NxB
    • Feb 2009
    • 1595
    Best Android phone?
    My motorola Q is on its last legs. I want to get a new phone.
    I have a CDMA carrier and I'd like to get one of the HTC phones which run or can be flashed to android.
    Whats the most bang for the buck? I want to get used and not carrier subsidized.
    • 31091
    Re: Best Android phone?
    i wouldnt run a google o.s.
    too much NSA type capability's
    • NxB
      • Feb 2009
      • 1595
      I'm going to modify the software anyway.
      Any phone with AGPS is transmitting your location back to the tower right now.
      • SluggerB
        Help with trying to fix phone that is not charging (Pics inside)
        by SluggerB
        I have two TCL A30 phones.
        Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
        New Phone: Works fine, bought as a donor board to try and repair Old Phone
        My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
        08-12-2024, 08:11 AM
      • keeney123
        new OS on a Sonim XP5s phone
        by keeney123
        To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
        I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
        05-13-2022, 07:19 PM
      • Grut
        JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
        by Grut
        My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
        Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
        When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
        Can anybody help me please finding the 17MB171 USB firmware to try to upload...
        11-15-2024, 03:12 AM
      • eccerr0r
        using exFAT on Android on smaller micro SD cards?
        by eccerr0r
        Are there any downsides to reformatting 32GB microSD cards to exFAT provided any other machines that could use this card also can read exFAT? (Mainly for using the card as the default "external storage," not as OTG storage but I suppose it shouldn't matter.)
        I have this weird thing with my carrier - I can use lots of GB of data but don't nearly have as much allocation if I tether ...
        So to stick it to them, I'll download with my phone to the microSD or internal storage, and then copy it off the card/internal storage. No difference in the bytes transferred, but...
        06-07-2022, 12:46 AM
      • mon2
        Hisense 55Q9G Android reset / factory firmware reload
        by mon2
        Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
        After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
        01-03-2024, 10:25 AM
