Audio Driver MPC clientpro 414 Win7
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Audio Driver MPC clientpro 414 Win7
    Originally posted by momaka
    Yup.
    It's not just the medical sector that does this, though. Seems like A LOT of corporations do this kind of thing and then charge it from the customer (or get rid of employees whenever they need to make tighter budgets meet ends.) If you've looked at all of the free stuff I've posted about in the last 2 years that I've got from my last job (including the SBC and SAS SSD I sent you), you can see just how much and what kind of perfectly good stuff goes to waste.
    I don't know why, but that kind of waste just annoys me for many reasons.....big waste of money, waste of good hardware, and then when it ends up in landfills...
    Thanks!
    Bookmarked and will try eventually when I get a chance (and some of that Zep2000 supposed magical stuff )
    This is the stuff.... I've used it for decades....I swear by it! It's pricey, but worth every penny! It's kept untold numbers of PC fans and other things from being trashed or having to be replaced....which in turn saved a lot of money. A little goes a long way. One can of that will last a LONG time!
    As for ball bearing fans... my only solution so far has been to replace the bearings. At one point, there used to be listings on eBay for 10 small BBs for $1-2 total (including S&H). I bought one, since I didn't know what the quality of the bearings would be like... and indeed only 6 out of the 10 bearings were "OK". Upon closer inspection, I think they were just recycled bearings. Nonetheless, that's still not too bad IMO for the $1 I paid. I managed to save 4 fans or so (two only needed 1 bearing changed.) Now they've jacked up the prices quite a bit more, so may not be as worthwhile, given the quality of the bearings. But still an option, though.
    Give the restoration a try....you'll be surprised!
    That would be interesting.
    I'd have to use one of the cheap gauges with a shunt resistor up to 20a. Even my good bench meter maxes at 10a......I really don't want to fry it...
    Even the P4's are, if they are on socket 775.
    On that note, isn't this the MPC AIO that you upgraded with the 3.4 GHz Cedar Mill I sent ya? At least I was left with th impression that this is that PC (and seems so from the best free/cheap scores thread.)
    Yes, this is the one that now has your old Cedarmill. The original was a 2.8GHz, probably a prescott 520 (I didn't check, but logical deduction). I did try a couple Pentium D's and 800FSB C2D's. but none worked...it likes the Cedarmill.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31296
      what hardware does linux detect?
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        32bit audio drivers for WindowsXP/Vista should work on Windows7 x86
        X64 versions require driver enforcement disabled, which requires you to set it in MSCONFIG. This is not recommended and for testing only purposes. Install Windows7 x86 and the driver should work.
        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
        • charif
          Audio Driver for Thomson P14C4BK128
          by charif
          Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
          I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
          The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
          Here are the details:
          • Model: Thomson P14C4BK128
          • Operating System: Windows 10 64-bit
          If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
          Thanks in advance for your help!
          04-30-2025, 05:41 PM
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • osrex
          LED DRIVER KEEPS DYING
          by osrex
          Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
          i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
          i have no datasheet at all for the LED lights, all i have is its length.
          long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
          as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
          05-05-2025, 03:36 PM
        • Iceking007
          Audio Driver/ Controller IC labeled GAD SHM? Datasheet
          by Iceking007
          Could anyone provide me with some information on an IC labeled GAD SHM?
          This is some sort of audio driver, it connects directly to left and right speakers via some inline resistors (small value of course).
          I've attached an image of the chip on board, I counted 20 pins. It might be some sort of op amp; it isn't the primary audio processor, as there is a separate dedicated chip for that.
          Thank you for your time....
          10-23-2022, 12:41 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
