Transformer hum
  • Eaglecrest
    • Jul 2018
    • 147
    Transformer hum
    Please forgive the ignorance, but I thought this might be a good place to ask this.
    I recently purchased a Chinese clone ultrasonic cleaner. When plugged in and powered on (i.e., power switch turned on) there is a high pitched hum. From what I uncovered so far it would seem to be a 120 Hz hum. It is relatively low volume, but clearly definable. Again, this is without the utlrasonic or heating functions turned on, just power to the unit. I am assuming this is related to the transformer.
    Is this something that I should worry about? Does it indicate an issue in waiting?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Transformer hum
    Should be 60 cycle hum if anything, 120Hz hum would be kind of unusual, could be a missing capacitor?
    Neither of which would really be high pitch however... Does it have a switching power supply or does it have a heavy transformer in it (which I'd think is rare nowadays...)
      • 31142
      Re: Transformer hum
      120Hz after the FULL BRIDGE RECTIFIER.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Re: Transformer hum
        Correct, but if the capacitor was working it should be 0Hz!
        • petehall347
          • Jan 2015
          • 4430
          Re: Transformer hum
          i wouldn't call 60 or even 120 hz high frequency
          • redwire
            • Dec 2010
            • 3912
            Re: Transformer hum
            I'd expect a low cost chinese power transformer, that pushes the core's flux density high to save on steel and copper. Hum for them is normal. The magnetic field in a power transformer has peaks at 2X mains=120Hz, so any laminations can vibrate at that, as well as 60Hz. It depends on what is vibrating. If you include power-line harmonics, it can get louder and make it seem to growl. They don't use varnish on the laminations (just the windings) in cheaper parts.
            Worst case the transformer is mounted wrong (shorted turn) so it will run really hot.
            • ohren
              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
              by ohren
              Hello!
              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
              Measured voltages with no load:
              After rectifier diodes
              12V: 6.17 V
              5V: 5.67 V
              Secondary transformer pins AC measurement (really don't know if this says anything)
              12V: 2-2.5 V
              5V: 1.04 V
              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
              03-18-2023, 10:33 AM
            • mikey5791
              Is it possible for transformer substitution?
              by mikey5791
              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
              My questions are
              1. How do i test to see if the transformer is in good working condition?
              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
              Hope you guys understand what i was asking. My intention is...
              11-03-2022, 02:11 AM
            • dennis_elx33
              3PHASE STEP-DOWN Transformer in Check
              by dennis_elx33
              Hello All,
              i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
              Problem statement: Power tripped Off
              Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
              Action Done:
              1) Replaced the faulty parts with good spare.
              2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
              12-02-2024, 06:52 AM
              ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
              This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 04:40 PM
              ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
              This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 12:00 PM
