HDD diagnostics program that works with SATA controllers
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    I need bootable CD with program similar to MHDD or Victoria that is compatible with SATA/ACHI controllers. In the good old days I could have just forced ATA/IDE mode in the BIOS, but many new computers come without compatiability mode and many of the old dos tools don't work at all.
    So, I need a program that can test the disk, show a map of the drive and access times, LBA-s of bad sectors. Sometimes when drive is failing, it slows down, while the data can still be read. Access times of over 300ms mean that the drive is starting to fail, no matter what SMART or simple disk testers tell you. I need out of box SATA support. I don't want to use the tools from the manufacturers of the drives, because I need separate tool for each brand and they do not provide access times information or LBA-s of slow/damaged blocks.
    Currently I use WindowsPE live disk and Victoria for Windows, because of this exact problem. But it is slow to load and I prefer the old style full screen disk testing program like MHDD.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • noppa
    • 41
    Re: HDD diagnostics program that works with SATA controllers
    For DOS you can try HDAT2, don't look nice as MHDD but it's
    good and updated.
    https://www.hdat2.com/
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      Originally posted by noppa
      For DOS you can try HDAT2, don't look nice as MHDD but it's ...good and updated. https://www.hdat2.com/
      I know about HDAT2, but the problem with it is that there is no disk map and I can't see if there are slow sectors. Sometimes the SMART is OK, the check completes without bad sectors, but the drive is full with slow sectors and is about to fail. Starting live Windows and then Victoria for Windows is too slow, I want to speed up things.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Try asking the developer of HDAT2 if he would consider implementing it?
        • hasefroch
          • Apr 2013
          • 42
          • Argentina
          You may be better off looking for an old motherboard with the chipset Intel 945 and using it as your "hdd scanning/diagnose" PC.
          Nowadays these are cheap, have the IDE/AHCI switch and will run pretty much any test program in existence (just use less than 2GB of ram if will run DOS programs, or some of them will throw strange errors).
          • DynaxSC
            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
            by DynaxSC
            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
            The behaviour is also really very strange, i.e.:
            • The disk shows always up in BIOS - so it is recognized, so far so good
            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
            02-23-2025, 01:33 PM
          • DynaxSC
            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
            by DynaxSC
            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
            The board is generally working now, all PCIe ports are working, Windows installs normally.
            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
            03-10-2025, 12:27 PM
            HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
            This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
            09-12-2024, 03:28 PM
          • welp
            PS5 Disk Tray issues.
            by welp
            I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
            Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
            Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
            So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
            With that knowledge I preceded to check all the fuses for the 12v rail on the main...
            12-19-2024, 02:04 PM
          • Stanley1843
            Windows 11 disk no boot
            by Stanley1843
            I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
            I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
            DISM /Online /Cleanup-image /Restorehealth
            The DISM.... command shows me the error 87.
            sfc /scannow
            chkdsk
            bootrec /FixBoot
            bootrec /ScanOs
            bootrec /RebuildBcd
            For some reason it writes(Total identified installations 0) like there no...
            10-18-2025, 04:41 AM
