Coil whine on old PWS-865-PQ (Supermicro 865W PSU)
  • TJJ
    • Oct 2020
    I've an old dual x5690 system (repurposed from a 4U EEATX server chassis) that's powered by a Supermicro PWS-865-PQ 865W PSU.
    I've no idea precisely how old this PSU is, but given that the x5690 is from 2011 it seems likely to be nearing 10 years old.
    As the machine was probably used as a server, it's likely to have been in operation 24/7/365.
    Under normal operation the PSU appears to operate perfectly normally, however when the machine is in standby mode it emits a fairly loud coil whine.
    Before I contemplate the expense of replacing it with a comparable unit, I'd like to know what risks I'm running; is coil whine from a PSU that's in standby mode a 'bad sign' ?
    Are high-end PSUs like this one designed to better protect system components in the event of a failure?
    I'm most concerned with the motherboard, as if that were damaged the machine would be essentially scrap, as replacement wouldn't be cost effective.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Coil whine on old PWS-865-PQ (Supermicro 865W PSU)
    I have several of this model that do this in standby...for years....it apparently just what they do....they've always been solid.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Reminds me of my Asus A7V8X-X (2003) motherboard. It would start squealing, especially in DOS and similar, LOL. (Via KT400) (socket 462)
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • TJJ
        • Oct 2020
        Thanks for the responses.
        I guess I'll stick with it as-is!
          master hoarder
          • May 2008
          • 12175
          Coil whine is normal in some PSUs.
          But before you conclude anything, maybe just crack its cover and check for badcaps anyways. Being a Supermicro PSU, I expect it's probably going to be something pretty high-end inside and not with crap caps... but just to be 100% confident, give it a check (and maybe even post pictures if you like. )
          That said, I do have a number of PSUs that emit loud coil whine in standby as well. The worst, though, is a Westinghouse LCD monitor I repaired a few months ago. That one has very annoying coil while. It took me almost a week to get used to it. The first few days, I'd even unplug the monitor at night before going to bed, because it was that bothersome. Once I got used to it a little (and once the new caps "broke in" a little after using the monitor for a few hot months in the summer), it didn't bother me as much anymore. It's been working great otherwise.
          • emestee
            • 228
            If the coil isn't too hot under load (and it shouldn't be), hot glue it. This mutes the whine.
            • Gjackson
              ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
              by Gjackson
              Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
              01-13-2024, 10:34 AM
            • Bitvive
              LG Flatron starts w. coil whine and power issues
              by Bitvive
              Hi ,
              My old LG Flatron recently started with coil beeping. This got worse every day for a few days until it also started having power problems.
              Now it also went off again after displaying the LG logo, then on, off again, then on and so on...
              So far I have measured the power supply unit, which delivers 19.21V and should therefore be OK. I removed the circuit board and connected it to the mains plug so that I could hear the coil beeping.
              During the beeping, I pressed on the coils with a non-conductive tool to see if the sound changed and to find...
              08-18-2024, 06:34 PM
            • 90Ninety
              Coil Whine , buzzing, identifying parts R9 Fury
              by 90Ninety
              I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
              I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
              Perhaps likely is that I am missing something else it could be , here is a stock picture...
              12-15-2022, 04:18 AM
            • Uranium-235
              SMD coil whine "chirps"
              by Uranium-235
              Does anyone have high frequency sensitivity hearing and a motherboards have tons of sounds coming from it? Is this just coil whine en masse? When data to the SSD has high I/O I can hear the clicks and chirps. Same with when the graphics drive inits. Network adapters, chirping after I connect the cable
              I can hear everything. Every time I put my ear to let's say an open Shuttle XH series pc (currently working on) in the next room it sounds like I'm in the middle of a the fucking public bird aviary
              Of course this isn't just the shuttle, though I think the small case...
              07-10-2023, 10:06 PM
            • Jumme
              Boston Acoustics Soundware 5.1 SUB: Agonizing coil whine!
              by Jumme
              So. Had my Boston Acoustics subwoofer for 4 years and it had a terrible coil whine squeal from day one.
              I RMA'd it twice, but both times it came back (after a 6-8 weeks return time) and had the exact same problem.
              Said they "swapped the amplifier module". As it didnt help, personally I feel more convinced its the PSU module. Company now bankrupt and I cant stand the noise:
              Its a high pitch coil whine tone -it's terrible agonizing, when worst, I hear it clearly 4-5 m from the Sub (because sits in corner).
              It wines without RCA input....
              02-14-2021, 04:03 PM
