Davda ransomware
  • eteng25
    • Mar 2014
    • 9
    • philippines
    Davda ransomware
    any suggestion to decript this kind of ransomware ( DAVDA )
    • 21016
    Re: Davda ransomware
    Recommended reading for all ransomware topics - https://www.bleepingcomputer.com/for...support-topic/
    • eteng25
      • Mar 2014
      • 9
      • philippines
      thanks
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Once you recover from this, do the following STAT:
        Implement a reliable offline and offsite backup system.
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • magneh
          Is this some kind of fuse resistor ?
          by magneh
          Hello guys
          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
          Seem to me like some kind of fuse resistor?
          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
          The red band is larger than the 4 others, but I dont have much experience with these components.
          Also one of the orange...
          02-10-2025, 07:54 AM
        • aurgathor
          Recommended replacement cap & voltage
          by aurgathor
          I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
          Questions:
          1. What are some the recommended caps for these values? (I will probably order from digikey)
          2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that r...
          08-25-2024, 05:14 PM
        • Fobo
          What kind of Thermal Paste is this?
          by Fobo
          I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
          What kind of Thermal Paste is this on the vrams insted of thermal pads?
          the picture is taken from youtube movie
          11-22-2023, 06:20 PM
        • KYBOSH
          Magical way of testing T-Con boards??!!?? - what kind of sorcery is this???
          by KYBOSH
          Please give me your opinion on this test method.
          i have never seen anything like it but want to give it a shot ASAP!
          04-22-2025, 09:35 PM
        • awe126
          Macbook Pro 16" A2485, 820-02100, battery service recommended, fan full speed, doens't charge
          by awe126
          Hello all,
          I bought a Macbook Pro 16" M1 Pro, A2485, 820-02100, which working flawlessly but not charging. I thought battery needs to be replaced but then started reading and it seems that problem will be in motherboard.
          Battery sign has cross sign and MacOS can't read battery stats. Fans are full speed but can be set down via Fancontrol software.
          I did start digging into in and found out below:
          Diode mode:
          SMBUS_BATT_SCL: 0.529
          SMBUS_BATT_SDA: 0
          SMBUS_BATT_SCL: 1.795V
          SMBUS_BATT_SDA: 0.948V
          Can anyone help...
          03-27-2025, 12:23 PM
