Using electronics power supply as laptop universal psu
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Like, power supplies like this
    https://www.amazon.com/Variable-Digi..._df_B07X2VZSL9
    And wire it with a wire and tip from this
    https://www.amazon.com/Universal-Lap.../dp/B07DNWSSMC
    Or would the dc be too dirty for something like a laptop that requires serious filtering from it's adapters?
    I just wish universal power adapters came im larger sizes for techs to troubleshoot laptops of all sizes, even high wattage gaming ones
    Maybe I could put a high ripple cap in line to smooth the dc out
    Maybe just...get a 280w adapter for a gaming laptop and split the universal wire with all those nice tips into it? Of course, the smaller size wire from the 120w adapter will probably heat up if I'm using the full 280w
    Ideas?
    • 31015
    Re: Using electronics power supply as laptop universal psu
    those bench supplies are much better than the laptop bricks, you can use one - but you need to get the matching cable for the laptop.
    the problem with most clone-cables is the wires are too thin, and they ususally dont have the "one-wire" memory chip used to tell the laptop that it's the right charger. (dell/hp mostly)
    of course if you have a faulty charger to recover the cable and possible memory chip then no issues.
    • diif
      • Feb 2014
      • 6978
      • England
      I use my bench power supply for laptops all the time.
      If you use it on Dell or HP then it won't charge the laptop but it will power it on.
      I have 19v 6300A Toshiba adapter with the standard tip (5.5x2.5) , these adapters plug into them https://www.aliexpress.com/item/4000253125083.html
        • 31015
        i can help with that,
        i have some pic code that simulates the dallas 1-wire chip
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          Yup, I do this too. With my scope, my variable volt bench supply output is far cleaner than any brick or even consumer-grade ATX PSU. The server grade ATX's OTOH tend to have very clean outputs....but I digress.
          If you have a laptop without a brick, you absolutely can power them up with a bench supply, you just need to know the voltage (most are 19v)....but like Diif said, some HP's and Dell's wont charge (always the 3-wire fatty plugs I've noticed).
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Yes it is super useful to run a laptop from a bench power supply when troubleshooting.
            Because you will also have the ability to set sensible current limits to prevent stuff from blowing up.
            And a built in power meter that tells you if any component you replaced improved things.
            Good example here: https://www.badcaps.net/forum/showpo...9&postcount=17
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
              09-06-2024, 09:30 PM
              Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
              This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 08:47 AM
