Update win 10 versions update?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys i notice on my old PC win 10 update version 2004 had issues so i reverted to version 1909.now i don't want win to auto update any higher than that ,so i found this ;
    https://www.cleverfiles.com/howto/di...indows-10.html
    do you guys use it and is it wise to disable updates ?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Update win 10 versions update?
    2004 is an optional update.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ivtec
      • Dec 2008
      • 1967
      Thanks mate; question; should i disable from farther updates?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        I would. I always ride the 'trailing edge' for updates....and let them hose other people's systems first....once deemed safe, I apply them manually.
        FWIW, if you don't want WU to update to the latest build, in GPEDIT, nav to Administrative Templates - Windows Components - Windows update; then enable "Turn off the upgrade to latest version of Windows through Windows Update". This enabled will only allow updates for your current build, and not upgrade it to the latest.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • ivtec
          • Dec 2008
          • 1967
          Thanks mate how i go to GPEDIT?
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            in the search box, type gpedit.msc
            Team : 49813
            Join in!!
            Team Stats
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              I think there is a little more you have to do if you have the home version
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                ohh....didn't think of that.... I always use pro.
                Team : 49813
                Join in!!
                Team Stats
                • ivtec
                  • Dec 2008
                  • 1967
                  Hi mates; Yes i have Home Edition,do you have a set of instructions? Thanks
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
                  • lordgeny
                    z490-f gaming bricked after bios update
                    by lordgeny
                    I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                    11-02-2023, 09:03 AM
                  • iMuhtaseb
                    A1706 2017 critical update
                    by iMuhtaseb
                    this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                    we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                    One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                    I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                    08-13-2024, 08:41 AM
                  • al3m0di
                    Update bios EFCN58WW to EFCN59WW
                    by al3m0di
                    Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                    I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                    The BIOS version is EFCN58WW.
                    When I turn on the device, it displays the message:
                    "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                    The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                    I've tried
                    07-29-2024, 10:32 AM
                  • DynaxSC
                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                    by DynaxSC
                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                    03-10-2025, 12:27 PM
