Windows 10 blues screen problem
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: Windows 10 blues screen problem
    Originally posted by Topcat
    That's where I'm at with it... Unfortunately, it's where things are headed. If I sell a refurbed system, I recommend 7 but also offer 10....user's choice. If it's a modern game rig, I recommend 10. It mainly depends on the users' needs. Right now it's probably a 50/50 one way or the other....which increased over the last year. Once denutted and modified, I can have it looking & functioning like 'old world' windows versus the fisher-price toy interface that should be named 'my first operating system'...
    1909 seems to be an OK version.
    While 1511 seemed to have a broken AHCI driver out of the box!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      I agree. Many times I install it, a couple hand-picked updates and then disable WSUS. It can still be updated manually if the client wishes, but it won't do it automatically.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • benek123
        RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
        by benek123
        I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
        The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
        When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
        I checked the EDID with the old screen - it is identical.
        What...
        09-24-2024, 03:28 PM
      • mmccomputer
        problem with replacing lcd screen
        by mmccomputer
        I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
        otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
        If anyone has any information on the subject...
        12-15-2024, 03:44 PM
      • Online_internet
        Windows re-activation problem
        by Online_internet
        I have a problem with windows activation. The laptop has the original version of windows 8 included by the manufacturer. The laptop worked on the original activated key for several years. Recently I wanted to try to see if I could still upgrade to windows 10 (it was a mistake). Of course, the time to upgrade to windows 10 has long since ended and my key was rejected. I came to terms with this and wanted to reinstall windows 8, I downloaded the system from the windows website, after starting the procedure it showed a window to enter the key, I entered and to my surprise now also...
        04-30-2024, 09:49 AM
      • jimjoe123
        LCD TV Green/Pink screen problem
        by jimjoe123
        I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
        Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
        Then each time...
        02-23-2020, 01:29 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
