Windows 10 blues screen problem
  • ErciaR
    • Aug 2020
    • 12
    • Sri Lanka
    I'm using a Windows 10 computer and everything was fine until yesterday.When I was working the PC suddenly became unresponsive for a few seconds, and then the screen turned completely in to blue and an error message appeared. Finally,it restarted itself.. I'm wondered what was happened and I haven't faced such an situation before. Why was that and is it a symbol of hardware fault of my PC?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Windows 10 blues screen problem
    What did the error message say ?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Yes, we definitely need to know the error message...
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        everybody has the windows 10 blues
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          LOL...
          Team : 49813
          Join in!!
          Team Stats
            • 31199
            i dont.
            • desert-rat
              • Mar 2014
              • 4103
              No windows blues here .. I use Linux mint.
              • ErciaR
                • Aug 2020
                • 12
                • Sri Lanka
                "Your PC ran into a problem and need to restart......" appeared on the screen and progress percentage was displayed..When reached to 100% it restarted itself
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  There's an error code a bit lower on that screen.
                  If it says "PAGE_FAULT_IN_NON_PAGED_AREA" or "BAD_POOL_HEADER", reseat the RAM.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    I use windows 10 and have worked on many windows 10 systems. So far I have yet to have any problems with it. Of course the ones I have encountered are usually 1903 and higher.
                    biggest pita sometimes is no F8 to safe boot, a no real way to enable it except to bring up a big menu every time. Big fail for techs but you can manually disable/enable it from USB without having to boot the OS, so mixed blessing
                    Techs have to learn 10, cause pretty much everyone is moving to it eventually, even if you're not using it yourself
                    I actually like it. Still use 7 on my shop box (will use both on my 'new' shop box). But for my gaming system it's practically required
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      That's where I'm at with it... Unfortunately, it's where things are headed. If I sell a refurbed system, I recommend 7 but also offer 10....user's choice. If it's a modern game rig, I recommend 10. It mainly depends on the users' needs. Right now it's probably a 50/50 one way or the other....which increased over the last year. Once denutted and modified, I can have it looking & functioning like 'old world' windows versus the fisher-price toy interface that should be named 'my first operating system'...
                      Team : 49813
                      Join in!!
                      Team Stats
                      • R_J
                        • Jun 2012
                        • 9588
                        I have'nt tried this yet but you should be able to enable F8 (safe mode) in windows 10 with the following:
                        In an elevated command prompt enter:
                        bcdedit /set {default} bootmenupolicy legacy
                        Then you should be able to hit F8 to enter safe mode when booting
                        I see if Fast Boot is enabled in UEFI firmware, there willnot be enough time to press F8 before windows starts
                          • 31199
                          the problem with offering any form of windows that still has updates is your gonna get blamed when the shit breaks.
                          i fix hardware and test it with a livedisk - o.s. is NOT my problem and i wont even discuss it with people.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I don't cover any OS as part of the warranty, only hardware. If a customer (or an update) break the OS, you can't really turn a customer away and not fix it. I won't do it for free though.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ChaosLegionnaire
                              HC Overclocker
                              • Jul 2012
                              • 3264
                              • Singapore
                              Techs have to learn 10, cause pretty much everyone is moving to it eventually, even if you're not using it yourself.
                              not me. for windows os related problems, i tell people to contact m$ for product support like stj said on here previously. technicians only fix hardware. we're not programmers so software is NOT our business. we're also not the ones who made windows. m$ did. so windows os related issues are the responsibility of m$ not us technicians.
                              also, how is m$ to know how to design a better product or how shitty they designed their products, if users dont flood their product support helpline with problems? makes them wanna shape up if they dont wanna have their product support department flooded with calls/emails or end up having to pay so much money to hire more product support personnel to deal with the shit ton of issues they get flooded with on a daily basis? hahaha!
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                As someone who had the title and job of IT Technician in a school for 7 years, we do both hardware and software/OS. They go together and are useless without each other.
                                What is it you do/fix for a job without having to deal with an OS or software ?
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  Exactly.... I can't shove a customer out the door and tell them to call MS for OS help....but I won't warranty anything software in any way....they will pay me to work on it.
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Yeah, with you on that one, although it would be nice to have an assistant I could pass the crap Windows 10 jobs too, it's the OS that keeps on giving (work), but then they all have really.......who warranties software ? lol
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      I don't know about across the pond....but you'd be amazed what people expect for free over here!!
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • ChaosLegionnaire
                                        HC Overclocker
                                        • Jul 2012
                                        • 3264
                                        • Singapore
                                        well, if they want free windows software support, then tell them to contact m$ for product support! thats what i meant!
                                        • benek123
                                          RedmiBook 15 pro 2023 Ryzen - after replace LCD screen work only in windows
                                          by benek123
                                          I replaced the screen and LCD ribbon in Redmi Book 15 Pro Ryzen 2023. After replacing, the image on the screen is only visible in Windows 11 - when the AMD drivers are loaded.
                                          The screen is backlit but there is no image in: bios, post, when loading windows, in linux (ubuntu boot from usb), windows 10 PE.
                                          When I disconnect the EDP connector from the board and connect the HDMI cable, the image is visible everywhere good, in the BIOS you can see 2/3 of the image, i.e. 1920 pixels out of 3000 pixels.
                                          I checked the EDID with the old screen - it is identical.
                                          What...
                                          09-24-2024, 03:28 PM
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • Online_internet
                                          Windows re-activation problem
                                          by Online_internet
                                          I have a problem with windows activation. The laptop has the original version of windows 8 included by the manufacturer. The laptop worked on the original activated key for several years. Recently I wanted to try to see if I could still upgrade to windows 10 (it was a mistake). Of course, the time to upgrade to windows 10 has long since ended and my key was rejected. I came to terms with this and wanted to reinstall windows 8, I downloaded the system from the windows website, after starting the procedure it showed a window to enter the key, I entered and to my surprise now also...
                                          04-30-2024, 09:49 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
