Socket 604 Cooling Solution
  • bigbeark
    • Jan 2010
    • 661
    I have a SuperMicro X5DPA dual CPU Socket 604 motherboard which works well except for the really loud CPU cooling fans. They are Thermaltake TT and run at about 6000 RPM so really annoying. Surely there must be adapters to use more modern coolers that are less noisy. I'm using the fastest CPUs available on this board 3.06 GHz.
    I'm thinking of the 775 tower type coolers. This board has 3-pin fans so the board has no influence on the fan speed.
    Any ideas? Thanks for this.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Socket 604 Cooling Solution
    I use LGA771 coolers for the all the time. The issue you can run into is the bottom plates for LGA771 sockets interfering with SMT components on the underside of the socket604. The fix is to not use the bottom plates, and instead use a nut & flat washer to attach the sink. Far better options out there for 604 CPU cooling with LGA771 sinks.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      You can use a fan voltage control board. Just watch the temps
      • Ace Perception
        Samsung R530 Bremen motherboard cooling
        by Ace Perception
        I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
        I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
        So I went in pursuit of...
        07-21-2020, 03:05 PM
      • pkslowk
        Debug Card Error Code and Solution
        by pkslowk
        Sr. Motherboard Debug Error Code Solution
        1 Intel 845 E9 Bios Related Problem
        2 Intel 845 D4 CPU Socket Related problem
        3 Intel 845 37 Bios Related Problem
        4 Intel 845 7C Bios Related Problem
        5 Intel 945GCPE 34 Bios Related Problem
        6 Gigabyte 845 2 Ram Related Problem
        7 IBM Server A6 A7 Ram Mismatch Problem
        8 Asus 845 29 CPU Related Problem
        9 Lenovo I946 97 C-Mos Jumper related
        10 Gigabyte 845 A0 CPU Related Problem
        11 Asrock G31M-VS D7 Bios Related Problem
        12 Compaq 845 BD-70G B0 CPU Socket Related problem...
        01-28-2021, 12:51 PM
      • Isabella91
        Possible to convert eMMC Socket to a micro SD Card socket?
        by Isabella91
        I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
        Read/Write a Micro SD Card from an eMMC Socket.
        I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
        Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
        Not to remove...
        01-14-2024, 05:10 PM
      • warsztat
        Acer AN515-57-577G JDIMM1 socket not working.
        by warsztat
        Hello, Acer AN515-57-577G JDIMM1 socket does not work. GH51G LA-L181P, 2x DDR4 RAM, both good, both work well in JDIMM2, neither works in JDIMM1. The laptop displays BIOS, when the JDIMM2 socket is occupied, you can run Linux on USB, then everything seems to work ok, there is internet access and you can browse the contents of the 512 GB SSD in Windows, but starting Windows ends with an eternal spinning circle, maybe there are corrupted files. When the RAM is inserted into the JDIMM1 socket, the laptop starts but there is no image and the downloaded current does not change and the output is ~2.25A....
        11-18-2024, 09:13 AM
      • AJ847.63e
        LGA 1700 Socket Replacement Tips & Tricks
        by AJ847.63e
        Hi All,
        Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
        I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
        07-24-2025, 06:57 PM
