m$ fucking W10 again
Re: m$ fucking W10 again
For me, the March, 2020 update was bad.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
I updated to version 2004 on my asrock deskmini a300, and I did have problems, notably it would be a blank screen coming out of sleep, so I ended up removing the graphics drivers and installed a beta amd one, yes radeon drivers still suck but I don't know weather to blame them or windows 10.My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
Sounds like when Windows 98 SE kept crashing, won't wake up if I installed the third party monitor driver said to be from Phillips for the 107S CRT, which it turned out I didn't even need for going to 85 Hz on my cheap Phillips 107S CRT.
Of course, the early-2000s was also a time where the BIOS for AMD systems, seemed a lot more buggy! Soyo was possibly the worst for this!
It would keep crashing at low load and usually found the PC crashed, if I walked away! So, they had a BIOS that was said to be from April, 2001, which fixed that.
But there was a work around for the Soyo SY-K7VTA-B motherboard: (KT133)
Lower Vcore by -0.025V, IIRC.Last edited by RJARRRPCGP; 07-14-2020, 05:03 PM.ASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
That is quite interesting.
My Server 2016 machine had its first ever BSOD a few days ago.
Maybe it is related to M$ fuckups then and not memory corruption as I feared.
I did run Memtest86+ and there where no errors found...
Bugcheck code was: 0x00000109
https://docs.microsoft.com/en-us/win...ure-corruption"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Yikes.... I just started test bedding S2K16 on a system....I haven't had this yet, but thanks for the heads-up.That is quite interesting.
After a round of updates on S2K12, Starcraft1 and AoE don't run anymore. Spit out an error on startup, no idea what's causing it.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I just did not try to find out why some apps did not work on 2024,i just reverted to older version 1909 and all was good ,and as they say if it works good don't change.I updated to version 2004 on my asrock deskmini a300, and I did have problems, notably it would be a blank screen coming out of sleep, so I ended up removing the graphics drivers and installed a beta amd one, yes radeon drivers still suck but I don't know weather to blame them or windows 10.Comment
by stj
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
Channel: BIOS Requests ONLY!
by Borse2008Hi everyone,
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by Egidio85Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
the fan does not start.
I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?
any advice on what to check? -
Hello All,
I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
https://www.hifivision.com/threads/m...-screen.98243/
Troubleshooting Summary: Majority Internet Radio - Flash Chip...-
- Loading...
