m$ fucking W10 again
    • 31013
    https://www.zdnet.com/article/window...ering-reboots/
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: m$ fucking W10 again
    For me, the March, 2020 update was bad.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • ivtec
      • Dec 2008
      • 1967
      Depend on the Hardware you have. if you have older PC Stay away from 2004 win 10 version,some apps don't work ,1909 version is
      ok.
      • BigTroll
        • Sep 2010
        • 1317
        • LAMBDA SOND
        I updated to version 2004 on my asrock deskmini a300, and I did have problems, notably it would be a blank screen coming out of sleep, so I ended up removing the graphics drivers and installed a beta amd one, yes radeon drivers still suck but I don't know weather to blame them or windows 10.
        My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Sounds like when Windows 98 SE kept crashing, won't wake up if I installed the third party monitor driver said to be from Phillips for the 107S CRT, which it turned out I didn't even need for going to 85 Hz on my cheap Phillips 107S CRT.
          Of course, the early-2000s was also a time where the BIOS for AMD systems, seemed a lot more buggy! Soyo was possibly the worst for this!
          It would keep crashing at low load and usually found the PC crashed, if I walked away! So, they had a BIOS that was said to be from April, 2001, which fixed that.
          But there was a work around for the Soyo SY-K7VTA-B motherboard: (KT133)
          Lower Vcore by -0.025V, IIRC.
          Arc A770 16 GB
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            That is quite interesting.
            My Server 2016 machine had its first ever BSOD a few days ago.
            Maybe it is related to M$ fuckups then and not memory corruption as I feared.
            I did run Memtest86+ and there where no errors found...
            Bugcheck code was: 0x00000109
            https://docs.microsoft.com/en-us/win...ure-corruption
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Yikes.... I just started test bedding S2K16 on a system....I haven't had this yet, but thanks for the heads-up.
              After a round of updates on S2K12, Starcraft1 and AoE don't run anymore. Spit out an error on startup, no idea what's causing it.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • ivtec
                • Dec 2008
                • 1967
                I just did not try to find out why some apps did not work on 2024,i just reverted to older version 1909 and all was good ,and as they say if it works good don't change.
