Help on replacement of touch-sensitive power button
  • ezli
    • Oct 2016
    • 9
    I have a S2440L Dell monitor which is periodically on and off, and I have searched and found that the problem is called "power cycles". a temporary solution can be used below:
    *Turn the monitor off
    *Disconnect the cable from the rear of the monitor
    *Press and hold in the monitor power button for 10 seconds
    *Reconnect the power cable to the rear of the monitor
    *Try to use the monitor
    This method works most time, but some time the monitor does not work which shows blinking/dark. So I guess that I should replace the touch-sensitive power button, but I don't know where to buy the part, and how to replace it by myself. Would someone please give me some idea or suggestions ? Thanks!
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Help on replacement of touch-sensitive power button
    You would need to examine the design of the "button" ("surface") to determine what it is responding to -- is it sensing the warmth of a fingertip? The capacitive load of the body attached to that finger tip? Is it photoreflective and noting that "something" is at or interrupting its focus?
    Once you know how it was intended to work, you can start thinking about how it might be failing to work properly and devise a remedy.
      Did you open up the monitor and perform visual inspection first?
      • ezli
        • Oct 2016
        • 9
        Thank you, budm and Curious.George for your reply!
        Surface of the button is flat and smooth, so I guess that the button is photoreflective. However, I am going to open the monitor and perform visual inspection first. At the same time learning basic troubleshooting and testing by following the links.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          It could also be capacitive or thermal.
          Try "pushing" it with a wooden dowel (so your body heat and "load" is separated from the switch).
          • themosttogain
            HP Envy 13-BA1565na with intermittent power button
            by themosttogain
            Hope someone can give me some suggestions on this because i'm at my wits end with it...
            I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
            Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
            07-12-2024, 03:03 AM
          • TimeRabbit07
            Asus FX517ZC charges but power button does nothing
            by TimeRabbit07
            Hi all!
            I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
            Here are its various numbers and identifiers:
            Model short: FX517Z
            Model long: FX517ZC-HN114W
            SN: NANRCX01S57842E
            CN: 3SDB 12M
            MFD: 2022-10
            Motherboard model: DA0NJLMBAE0 REV E
            Symptoms:
            The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
            History so far:
            The...
            09-04-2024, 05:48 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • hoarderteks_kyriakos
            Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
            by hoarderteks_kyriakos
            Hello.
            Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
            Here is what happened:
            At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
            Yesterday, 07:33 AM
          • Darren Hibbert
            MacBook A2179 Audio board+Power button boardview & schematic needed
            by Darren Hibbert
            Hi.
            Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
            There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
            Many thanks. ...
            08-21-2025, 02:38 PM
