asus cuv4x-e problem
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    does anybody know the value/ polarity of the tantualm (i cant spell tonight) cap right next to the cpu socket? its on the side facing the i/o plate.
    it got crushed a long time ago. it still ran but i assume i better fix that if i plan to use it again.
    sigpic
    (Insert witty quote here)
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: asus cuv4x-e problem
    post a pic.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      its crushed. a pic would be useless if all that is left is metal paddles.
      sigpic
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        post a pic anyway.might tell us what it does.most tants and mlcc near the socket are on vcore.probably run ok without it.clear off the remains in case it is shorted.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          its right on the socket... crushed when i used a socket a fan with a 3-hole clip... there is like .5 mm between it and the socket. it did run without it. ill clean it off... it will say hi to a lin-lin soon.
          sigpic
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Post a pic - for location.
            I have an Asus CU-something or other, that was a trade in that I've never even looked at.
            Might be similar.
            Mann-Made Global Warming.
            - Dr Seuss
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              ill use it w/o it, it ran fine that way.
              sigpic
              • everell
                • Jan 2009
                • 1514
                Post pictures
                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  NOTE- i marked out what the original creator of the pic had an arrow to. use the bold arrow on the left instead.
                  sigpic
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Now that I dug it out. [System was still almost fully assembled.]
                    It's a CUSL2 Rev:1.02
                    Doesn't look close enough in the area of your circle to help.
                    This'n has 7 caps to yurs's 5 and the Toroid is laid down flat instead of standing up.
                    - Dr Seuss
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      yeah, th cusl2 is not even close... i have one too... hate the intel chipset in it...
                      sigpic
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        I have a CUV4X-C rev. 1.02 which has more electrolytics around the socket, but nothing like a Tantalum
                        But seeing it doesn't even have empty an position for an ISA slot, it's probably quite a different PCB assembly
                        I think you'd be in a minority hating a CUSL2, perhaps one of Asus's last trustworthy products
                        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                        • gg1978
                          • Dec 2004
                          • 431
                          If it's what i'm looking at, that's not a cap, it's a diode. looks like a flyback diode for the CPU VRM.. I've got a CUV4X-E right in front of me, and the only thing even remotely that close to the CPU socket on that side is D4, which is connected across Q6, a MOSFET in the CPU VRM. The part number on the one here is PJ13 on the top line, and SS12 on the bottom line..
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            it was black and box shaped. right next to the clip.
                            edit, the pic was only to show position, that is not my board model. i screwed op.
                            and yes, gg1978, that is the board you sold me.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              ok, its d4.
                              i had to switch standoffs so while i had it open, i looked.
                              sigpic
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                ill see if its posts tonight... a celeron 400mhz will be sufficient to test with.
                                sigpic
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  inconclusive. the fact that its that old made it a no go from the start. ill have to wait for the lin-lin to come in
                                  sigpic
                                  • pfrcom
                                    Oldbie
                                    • Jun 2006
                                    • 1230
                                    Does it support PPGA processors like Celeron 400 ?
                                    Many boards of similar vintage support only FC-PGA processors
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      idk. its a pIII coppermine board i plan to put a lin-lin adapter in so i can put a tulatin celeron in it
                                      . its in the mail... waiting for it...
                                      sigpic
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        (play taps)
                                        its doesnt like the lin-lin. i bet the lack of diode and a bad cmos battery did it. ill replace it with a socket a board (msi k7t turbo), which will take my ram.
                                        sigpic
                                        • AtelierRepa
                                          ASUS X712JA problem
                                          by AtelierRepa
                                          I have a problem with the bios, let me explain.
                                          With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                          I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                          My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                          The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                          06-15-2024, 04:33 AM
                                        • Dobrowol
                                          Asus GA402RK keyboard and kb backlight problem
                                          by Dobrowol
                                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                          04-28-2025, 04:30 PM
                                          ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                          This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                                          09-07-2024, 02:50 AM
                                          ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
