Audio apps
  • stevo1210
    • Oct 2006
    • 4156
    Audio apps
    I have an IBM iseries laptop here that I am trying to turn into an mp3 music player to serve as a party jukebox. It has a celeron 700 MHz CPU, 192mb ram and a 20gb hard drive. It currently runs xp pro pretty well. But I was thinking if there was some media player software that would be suitable for it? I'd even switch to linux if I had to.... So what should I do?
    Thanks.
  • kikkoman
    • Jul 2007
    • 691
    Re: Audio apps
    depends on what you want to do.
    if all you need is a playlist to drop songs into, then foobar2000 or winamp is fine (foobar interface is simpler and less bloated but the winamp's media library is easier to use imho)
    if you want to do some basic mixing then maybe you can get away with winamp with plugins. (haven't looked into those a while) .
    and there are complete dj software packages available of course (eg PCDJ) but most of them cost $.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • NxB
      • Feb 2009
      • 1595
      Re: Audio apps
      Any MP3 player will do it. I can play mp3s on a 266mhz p II. I would dig up more ram for it to make it a little faster. You might even be able to do visualizations.
      • toastygoodness
        • Jul 2005
        • 813
        Re: Audio apps
        maybe jetaudio /cowon media center?
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • kokopelli75
          Victrola multi-player - No audio
          by kokopelli75
          Hello!
          My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
          01-11-2025, 03:51 PM
        • nervous_capybara
          Repairing the Hitachi DA-6000 CD player
          by nervous_capybara
          Hello everyone !
          I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
          Feel free to share your experience if you ran into other issues.
          DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
          CD tray would not come out of the player
          I could hear a motor spinning inside the player but the CD tray would not come out.
          Turned out that the issue was the CD tray belt that aged poorly and began to...
          11-05-2025, 03:11 AM
        • i_am_patch
          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
          by i_am_patch
          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
          04-30-2024, 08:20 PM
        • silver60618
          Macbook M3 A2991 Speaker Audio Amplifier IC
          by silver60618
          Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
          I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
          09-26-2025, 12:25 PM
