Does anyone know where I can find Windows XP update from
    • Jul 2011
    • 6066
    I have some old desktop computers that were given to me ( no they did not come with hard drives )
    The installation disk that I have of Windows XP is when it first came out
    I have a Radio Shack meter that I want to use on it
    The manual says Windows XP ( or higher but we will see if this is the case or not )
    This meter has a serial port not a USB output
    I going to recap the mother board and power supply on one of these old desktop that has serial port so I do have not to use a converter box
    I do not plan to use this computer on the internet but I know that Windows XP had updates I have to see if I can find the update disk I know I have but can I find it that the question it was so long ago
  • R_J
    • Jun 2012
    • 9588
    Re: Does anyone know where I can find Windows XP update from
    Windows uppdate for xp should still work, you may need to find ie8setup for windows xp and install it first, I don't remember. If not there are lots of copies of windowsxp_sp3 around on the internet.
      • 31200
      https://getintopc.com/softwares/oper...nload-1339359/
      https://getintopc.com/softwares/oper...nload-6960719/
      • R_J
        • Jun 2012
        • 9588
        Or you can install what you have and get sp3 etc. from the microsoft update catalog site https://www.catalog.update.microsoft...q=windows%20xp
        Or for windows xp sp3 iso https://isoriver.com/windows-xp-sp3-iso/ you will need to provide your own licence key
          • Jul 2011
          • 6066
          Thank you for the links this will help me a lot
            • Jul 2011
            • 6066
            Thank you for these links this will help me a lot
              master hoarder
              • May 2008
              • 12175
              If you have an original install XP CD (that is, no service packs integrated), or just one with SP1 or SP2 only - do NOT connect the PC to the Internet! -Not even for updates!
              SP2 and older versions are still susceptible to getting infected with a worm known as "DownAdUp". You don't have to go to any website - it will get picked up automatically. SP3 has an update that addresses this vulnerability. That said, I still have SP2 PCs on the net, but they have been patched specifically for that vulnerability: update KB958644. You will need Windows Installer 3.1 to run this update, though (KB893803).
              But really, just get an SP3 ISO and be done with that - probably easier and a little more secure.
              • R_J
                • Jun 2012
                • 9588
                Here are some of the part numbers of the versions, searching the part number will likely result in an CD ISO
                English:
                Windows XP Professional (SP3) Retail - Part No. x14-80428
                Windows XP Professional N (SP3) Retail - Part No. x14-92445
                Windows XP Home (SP3) Retail - Part No. x14-92413
                Windows XP Home K (SP3) Retail - Part No. x14-92386
                Windows XP Home KN (SP3) Retail - Part No. x14-92388
                Windows XP Home N (SP3) Retail - Part No. x14-92393
                Windows XP Professional (SP3) VLK/Corporate/Volume - Part No. x14-73974
                Windows XP Professional KN (SP3) VLK/Corporate/Volume - Part No. x14-92432
                Windows XP Professional K (SP3) VLK/Corporate/Volume - Part No. x14-92430
                Windows XP Professional N (SP3) VLK/Corporate/Volume - Part No. x14-78118
                Windows XP Professional (SP3) Checked Build - Part.No x14-92469
                Windows XP Professional (SP3) OEM - Part No. x14-72249
                Windows XP Home (SP3) OEM - Part No. x14-73422
                  • 31200
                  is the radioshack multimeter in this list?
                  https://sigrok.org/wiki/Supported_hardware#Multimeters
                    • 21634
                    Wrong thread .
                    • R_J
                      • Jun 2012
                      • 9588
                      Originally posted by SMDFlea
                      Wrong thread .
                      Not really, read post #1
                        • 31200
                        lol - always read a whole thread before jumping in!
                        because if it's all to read a multimeter, and if sigrok supports it - then we dont need xp at all.
                        • T4-BR
                          T470S - TPM issue since TPM/BIOS update from Windows Update
                          by T4-BR
                          Many thanks for the high quality ressources available on your website.
                          I'm currently facing some issues with my T470S:
                          - I sat a Supervisor Password using special chars which was causing issues
                          - Access to BIOS was locked but I was still able to use my PC
                          2 weeks ago, I got an update of BIOS/TPM from Windows Update.
                          Computer restarted and after Lenovo logo a loading bar appeared and at the end something went wrong + an error popped.
                          Computer restarted one more time and I got the prompt for typing Bitlocker...
                          09-26-2024, 02:50 AM
                        • 0xx
                          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                          by 0xx
                          Hi folks,
                          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                          I assumed that Windows Update was interrupted due to closing...
                          09-14-2025, 03:46 PM
                        • davidebeatrici
                          Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                          by davidebeatrici
                          I had 3 people contact me in a week because Windows suddenly didn't boot:
                          As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                          The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                          Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                          06-17-2025, 12:59 PM
                        • bogart219
                          Lenovo ideapad 5 windows 11 update disable charging circuit?
                          by bogart219
                          Hello fellows. My Lenovo ideapad5 151al7 doesn't charge my battery, this seemed to happen right after an win 11 update, at least that is when I noticed it. I rolled back the update but it didn't matter. The laptop doesn't work off of the power adapter, which btw, I always leave plugged in and never really use the battery. New power adapter and battery, same problem. USB-c connector. The battery monitor in setup says "charger not installed", (but it is). Using a usb tester, with the battery plugged in it reads 20 volts but no current. With the battery unplugged it only reads 5 volts with...
                          05-05-2025, 10:31 AM
                        • unick
                          Laptop HP 850 G2 Keyboard error after Windows 11 update
                          by unick
                          Hello
                          i have following problems on HP 850 G2 laptop and 840 G2 laptop. After win11 update 24H2 the keyboard and touchpad stop working. I delete the keyboard from device manager and restart : work. If i shut down the laptop and restart after 5 min the problem apear again: no keyboard and no touchpad active. I have used also hp driver from oficial sit but no luck. I have modified with regedit " i8042prt Start REG_DWORD with 1, but no suscces. Any ideea?
                          09-15-2025, 07:47 AM
