ok to use 1500 uf to replace 820uf?
  • berniedd
    • Mar 2007
    • 119
    Asus P5V800-MX mobo keeps on hanging, has many 820 uf 10v bulging caps. About 12 of them all over the board, and I guess I'll be replacing all of them, even those not yet bulging. All I have right now are 1500 uf Samxon caps. I think I'll be okay with this 83% increase in capacitance; does anybody think otherwise?
  • Player2
    • Aug 2009
    • 98
    Re: ok to use 1500 uf to replace 820uf?
    That sounds like way too much of an increase to me. Hopefully someone more knowledgeable than I can confirm/deny this, but generally I try to keep the capacitance within ~20% of the original if I absolutely must use a different size.
    • c_hegge
      • Sep 2009
      • 5219
      I agree with Player 2. Try to keep the capacitance the same. If the manufacturer used that capacitance, it was probably because the circuit was designed for it. A small increase or decrease may be ok (no greater than 20%), but going from 820 to 1500 is too much of an increase and not recommended.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16951
        it would probably be ok. I've replaced 820uF caps with 1000uF caps many times, never had any issues...but I've never gone that high.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • NxB
          • Feb 2009
          • 1595
          It would be fine. I think you are safe up to 2x of V and uF. A slightly higher rating is ideal. I'd order 1000uf caps. Make sure they are low ESR caps.
          • MegaOne302
            • Apr 2009
            • 94
            Yes, don't worry it'll work fine. I've done it on a few motherboards and LCD inverters with no problems. Just make sure the temp rating (usually 85c or 105c) meets or exceeds the original. Also, if they're close to each other make sure you have the space before you start soldering.
            Does an idiot make a sound if no one’s there to hear them talk?
            • NxB
              • Feb 2009
              • 1595
              If you use general purpose caps it will run worse. I'd definitely check out the datasheet.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                If the ESR is the same or less and the Ripple is the same or more and they are 105c Temp caps then it will be fine as long as you don't have SO MANY that the inrush current when you turn on the power supply trips it back off by way of tripping off the over current protection feature.
                Mann-Made Global Warming.
                - Dr Seuss
                • berniedd
                  • Mar 2007
                  • 119
                  I guess the psu would have to be rather hefty then to prevent it from tripping off.
                  • gdement
                    • Jan 2007
                    • 690
                    I'd test the locations with a multimeter and figure out what's in parallel. Combine that with ESR info from the datasheets for the old caps and new ones. Depending what you find, you maybe can just install caps at certain positions instead of all of them.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      That's not what I was trying to say.
                      "If you replace ->SO MANY<-"
                      - Can't say what 'so many' [too many] is on any given board.
                      Something you just have to try to find out.
                      I can't see what you are looking at or have.
                      Are all these caps on the same rail?
                      Are they all VRM. Some VRM and some not?
                      Are any PI filters with a different size cap on the other side of the inductor?
                      Caps on boards have an acceptable range based on the reference design board.
                      For example the reference design your board was built to -might- say something like 820 to 1500 uF, or it might say 330 to 820 uF. [In other words the caps you find installed might be at the upper or lower end of the acceptable [design] range.
                      A cheap 'gutless wonder' PSU or one that's barely enough for the system might have problems if you are pushing it.
                      Probably not a problem here, but traces on circuit boards to have current limits and they can burn in half just like an overloaded wire.
                      I saw a thread somewhere where someone upped a bunch of 1000uF to something like 3900uF or 4700uF [long while since I read it] and the system wouldn't boot with any PSU.
                      On the other hand I've seen isolated 'experiments' where going up drastically in uF worked fine. [Though seldom with that many caps.]
                      Going 820-1000, 1200->1500, 1500->1800 or similar 'up one size' is well tested by many and can be called safe with some level of confidence.
                      Odds are you won't have a problem either but what you are doing is not well tested so don't take all the "it SHOULD work" comments as "it WILL work".
                      It SHOULD work, yes. But no guarantees.
                      I just didn't want to leave the idea in the thread that upping uF by large amounts is 'universally okay'.
                      - Dr Seuss
                      • berniedd
                        • Mar 2007
                        • 119
                        PCBonez, most of these caps are Vcc filters "guarding" specific parts of the mobo: each PCI slot has one of them, and so do the USB ports at the back of the board, the Keyboard port, the AGP slot, etc. No, none of them are used in conjunction with an inductor.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          - Dr Seuss
                          • MXM
                            • 430
                            • Unknown
                            im replacing 820uf - 4v with 1000uf - 16v... whats your opinion? theyre all close to the processor....
                            We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              At 4v those sound like CPU VRM output caps. [Vcore - aka CPU Vcc.]
                              Provided that you do not go to a higher ESR or lower Ripple rated cap, 820->1000 uF should work out fine.
                              - Dr Seuss
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16951
                                Are they lytics that have vented or polymers? If they're polymers, its unlikely they're bad anyway. If they're VRM outputs, you could use an 820uF 2.5v polymer safely most likely (depending on the CPU's core voltage).
                                Post up a pic if you can.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • MXM
                                  • 430
                                  • Unknown
                                  Thank you both.
                                  • berniedd
                                    • Mar 2007
                                    • 119
                                    Long time no see, but here's an update, guys. I went ahead with the 1500 ufd replacements and the mobo's been running great for the last 1.5 years.
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16951
                                      Ahh thanks for the follow-up! I figured it would be ok!
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • mikkele86
                                        Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
                                        by mikkele86
                                        Hello Im renovation a Luxman R-5045
                                        On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
                                        because thats what i got in stock :/
                                        04-16-2024, 12:37 PM
                                      • yuuki47
                                        ASUS P5KPL-AM.I bought caps with a big tolerance rate
                                        by yuuki47
                                        I have an ASUS P5KPL-AM board with swollen and leaky capacitors. Amazingly, it still works, but I'm guessing it won't be long before it doesn't so I'm looking to replace the capacitors. All that electrolyte is probably not good for the traces too.
                                        Anyway. Every cap on that board that is 820uf 6.3v is swollen, so that issue is isolated to those specific caps. They're TK AWTY caps. Never heard of them but I suppose they're bad quality.
                                        To replace them, I bought Rubycon ZLH capacitors with the exact same 820uf 6.3v spec. But when I went to test...
                                        05-20-2023, 01:14 PM
                                        HP EliteDesk 705 G3 EliteDesk 700 PRO 1500 Specification for Upgrade or Repair
                                        This specification for the HP EliteDesk 705 G3 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 705 G3 boardview and EliteDesk 705 G3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                        09-12-2024, 02:15 PM
                                        HP EliteDesk 705 G3 EliteDesk 705 PRO 1500 Specification for Upgrade or Repair
