HP d530 CMT
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: HP d530 CMT
    yes, if it was 3rd detected when you had 3 drives, then that would do it.
    sigpic
    (Insert witty quote here)
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Re: HP d530 CMT
      I have changed drive letter in Xp and yes it did give me a warning that stuff might not work. I just may have gotten lucky because my other progies picked up the changes and or let me set up the letter change manually. Got to go....Going cabbing today in a Nort-Easter blow. I'm a dumb ass, I know.....
      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
      Mark Twain
      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
      John Paul Jones
      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
      Rod Serling
      • Phaihn
        • Jan 2009
        • 842
        Re: HP d530 CMT
        well in that case how do you change drive letters?
        My Computer.
        AMD APU A4-3300 2.5ghz 1mb cache
        Motherboard GigaByte GA-A75M-S2V
        Kingston HyperX Blue DDR3 8GB (2x4GB)
        SB Audigy 2 ZS [B800] Sound Card
        500GB WD Caviar® Blue™
        1 Terabyte WD Caviar® Black™
        2 Terabyte WD Caviar® Black™
        • washu
          • Jul 2009
          • 310
          Re: HP d530 CMT
          Disk Management in Computer Management
          Right Click your partition and chose Change Drive Letters and Paths
          • Phaihn
            • Jan 2009
            • 842
            Re: HP d530 CMT
            yeah figured that out but it wont let me change it and i found i cant do it on my main system too.
            My Computer.
            • clabr
              Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
              by clabr
              Need help to solve some problems with this laptop.
              After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
              After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
              Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
              Before this had happened I observed some other problems:
              When I tried replacing original mecanical HDD with a SSD HDD could not get them...
              12-02-2021, 08:09 AM
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
            • Luke Anders
              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
              by Luke Anders
              A few details about the laptop itself:
              Name: Lenovo Legion 5
              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
              BIOS Version: GKCN60WW
              EC Version: GKEC65WW
              Serial Number: PF39AQ7Z
              Board Model: NM-D562 Rev 3.0
              RAM: 16GB Installed, DDR4 (brand new)
              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
              I bought this laptop recently from eBay as a faulty device....
              10-12-2024, 05:13 AM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
