Laptop Hard drive failure analysis
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Just digging through my box of old HDs waiting to be sent to the scrappers. Most of these drives came from Dell c640s
    (6) Fujitsu MHS2030AT (all dated 2003-05)
    (2) Fujitsu MHT2030AT (all dated 2003-07)
    (6) Hitachi Travelstar DK23EA-30 (no date)
    (2) Hitachi Travelstar DK23BA-20 (no Date)
    (2) Hitachi Travelstar 30gb dated Jan and May '03
    (1) Hitachi Travelstar DK23DA-30F (2002.06)
    (1) Hitachi Travelstar 60gb (Aug-05) replacement for previously failed
    (1) IBM Travelstar 40gb (Nov-02)
    (3) Toshiba 20gb (no date)
    (1) Samsung MP0402H (2006.01) was a replacement for a previously failed drive
    (Newer SATA Drive, not from c640) Hitachi HTS541010G9SA00 Nov-06
    And now, here's what's in the "good" pile. Good means no SMART errors, and passed 3 pass write test with no errors-
    (3) Hitachi Travelstar DK23EB-40 (no date)
    (1) Hitachi Travelstar IC25N040ATCS05-0 (APR-03)
    (3) Fujitsu MHT2030AT (2 dated 2003-07, 1 dated 2005-07)
    (1) Fujitsu MHS2030AT (2003-05)
    (1) Fujitsu MHV2040AH (2005-11)
    (1) Seagate Momentus ST94811A (date code of 04237, whatever that means. This was a replacement for a failed drive)
    (1) Samsung MP0402H (2006.02, replacement for a failed drive)
    So, basically, most of the failed drives are 30gb drives, and most of the good ones are 40gb. We're currently in the process of replacing every drive with Western Digital WD800BEVE drives as a pre-emptive strike for the high failure rate we're seeing. At the same time, we're also popping 2x512mb DDR in them to bring them to the max 1gb. With those two upgrades, speed is increased a ton. Every person I've done the upgrade to has emailed back saying they love how fast their "old" laptop is now. I mean, they are P4M 2.0ghz, so they should be working fine with WinXP, mail client, IE, and office...
    Now all I have to worry about is failing motherboards. I've seen a few in our fleet, and when that happens, they just get scrapped.
    Ludicrous gibs!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Laptop Hard drive failure analysis
    BTW- we still have 41 C640's in circulation. 17 are still on my list to upgrade. Can't wait to have everyone done so I can breathe a sigh of relief. Normally, these drives die slowly... at least slow enough that I can still get a Ghost image off of them to salvage data. But sometimes... they just stop working.
    Ludicrous gibs!
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Oh, and I forgot... I'm also taking the keyboard off to clean out the dust/crumbs that 5 years brings, and at the same time, replacing the CMOS batteries. I found a guy selling a bunch on eBay, and snagged 10 of them for now. They're all getting to the point where if you let the main battery die it'll lose the settings.
      Ludicrous gibs!
      • NxB
        • Feb 2009
        • 1595
        I have stacks of hitachi travelstars. Many 02-04, most got the click of death even after mild use. 30-40G range was especially bad. Also seems like anything IBM branded is the worst off. My MH17951 just died taking my Rockwell PLC software with it. I left it downloading all night, rebooted the computer and got click of death.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Yeah, even the drives that "test good", I'm not really sure that I'm going to do anything with them, due to age. For now, they'll take up a little space in my cabinet 'til I decide to chuck them, too.
          I'm hoping that these WD drives will last another 5 years (if the rest of the machine holds up). Really, when you think about how old those original drives are... and most didn't start failing until this year, it's really not too bad of a track record. They are in laptops used by our traveling salesmen, after all. Lots of abuse...
          Ludicrous gibs!
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            i have 2 6gb from 99 or 00. but my 30 pooped on me a while back. ibm sucks. i hope my 60gb seagate out of a one touch III lasts longer...
            sigpic
            (Insert witty quote here)
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i hope your luck with the wd drives is better than mine.
              i rebuilt the computers,servo's,and power supplies on 4 deckle s20 turbo tool grinders.used wd scorpio 80's in all 4.these are rubber mounted and have good airflow.
              none lasted more than a month.
              glad i imaged these suckers after the overhaul and file transfer!
              i replaced with seagates and they are still fine.
              • NxB
                • Feb 2009
                • 1595
                Sometimes you can combine boards and platters to make a good drive. I see some older drives working perfectly, I think its hitachi/tosh/"ibm" making shitty drives.
                I bought a WD scorpio 160 5400rpm, I'll see how long it lasts. My desktop drives run forever, my laptop drives keep dying. The hitachi ran fine in my desktop for over a year and a few days after I put it in a laptop.....
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  The WD drives I'm installing have a 3 year warranty. I'm guessing that these laptops will probably be retired by then.
                  Ludicrous gibs!
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    That's okay... I've had horrible luck with Seagate drives lately. It seems that no matter what you hear about one type of drive, someone's had the exact opposite experience...
                    Ludicrous gibs!
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      we have a lot of wd desktop drives. all our desktop drives (functional):
                      2x wd 320gb pata
                      1x wd 160gb pata
                      2x wd 40gb pata (silver housing/cover, one might be dead)
                      1x wd 40gb pata (black housing/cover)
                      1x wd 6gb pata
                      1x maxtor 10gb pata (will be shipped to someone soon)
                      1x maxtor 250gb sata
                      1x quantum 2.5gb pata
                      1x conner 450mb pata
                      1x seagate 80gb pata
                      1x seagate 450mb pata
                      as for lappy drives:
                      1 hitachi 20gb pata ? (lost in an enclosure, may or may not work)
                      1 ibm 20gb pata
                      3 ibm 6gb pata (one thicker and dead, other two normal thickness and running)
                      1 ibm 30gb pata (clicker o' death)
                      1 seagate 60gb pata (pulled from a beat-up one touch III)
                      1 seagate 160gb sata (in eee pc off on warranty repair)
                      yup, ibm sucks. hope wd works! i have a 6 gb from 1998 to prove they last!
                      sigpic
                      • i4004
                        • Oct 2006
                        • 2029
                        exactly.
                        essentially no hdd should be trusted.
                        that said, i have good experience with wd.
                        <wink>
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Yea, I think most manufacturers have equal quality, bar the lemon with firmwares or just plain crappy models every once in a while
                          What is much more important is probably if your batch of drives was built properly in the factory (monday ex etc?)
                          And how that batch of drives was handled by the shipping companies before you got them in your hands
                          • NxB
                            • Feb 2009
                            • 1595
                            I'm gonna beat the shit out of the scorpio and see how it holds up. I had to buy it retail so if it fails in the first month i'm getting my money back and buying a drive off ebay.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              Another dead Hitachi Travelstar
                              Model IC25N040ATCS05-0
                              PATA
                              5400rpm
                              40gb
                              Jul-03
                              Failure: Locked up spindle bearings
                              Currently chilling in the freezer.
                              Ludicrous gibs!
                              • cheese007
                                • May 2009
                                • 85
                                Meh, I've had good experiences with WD and Seagate. I have a WD drive that's about 12 years old, it sounds awful and has sounded that way for the past 2 years, yet it keeps going. I don't think I've ever had a Seagate fail.
                                • Megawatt
                                  • 81
                                  • South Africa
                                  anyone had any problems with samsung drives? i recently got a few and was looking for some real world analysis
                                  • Gibon378
                                    What caused the BSOD?
                                    by Gibon378
                                    Hello there!
                                    I was doing some usual stuff, browsing the internet, listening to music, coding, etc. and my computer froze. It looked like the website couldn't process the request (logging into the account, there was the loading symbol) and it took a few seconds, then my computer totally froze except for the mouse cursor. It lasted for about a minute and I got the BSOD. It happened yesterday and today (just now).
                                    I managed to get the MEMORY.DMP content, but I don't really understand it. Could somebody help me?
                                    Code:
                                    ************* Preparing the environment for Debugger
                                    06-23-2023, 06:20 AM
                                  • gshark1
                                    Gaming laptop rtx 2070: Disappearing GPU after BSOD, Only using integrated graphic now
                                    by gshark1
                                    Hi, I've exhausted lots of software side options to try and fix why my nvidia 2070 GPU has disappeared from my gaming laptop MSI GL75-10SFK. The system boots and functions normally but only using Intel integrated graphics. Before, it was working fine then began having some blue screens. (I will attach the system event and mini-dump at the end of post). After a few days of the occasional BSODs it finally disappeared from device manager and never came back. I researched and attempted to troubleshoot this issue but im out of options and was wondering if yall had some ideas maybe on the hardware side....
                                    12-29-2023, 04:42 PM
                                  • Sus256
                                    HISENSE 65E7KQ PRO - no boot
                                    by Sus256
                                    Hi all!
                                    HISENSE 65E7KQ PRO
                                    RSAG7.820.13512 - chassis
                                    MT9618BAATAB - cpu
                                    RSAG7.820.12059 - power
                                    HD650Y3U77 - panel
                                    KLM8G1GETF - emmc
                                    Replaced emmc.
                                    Terminal log
                                    UART
                                    AC_ON
                                    E-B
                                    FDE enabled
                                    06-01-2025, 02:11 AM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • massimomax
                                    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                    by massimomax
                                    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                    spero che qualcuno può averlo per riprogrammare eprom. grazie
                                    Post in English !!!
                                    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                    02-28-2025, 07:27 AM
