Oh yay, another driver issue.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Oh yay, another driver issue.
    wow. 3 pages of cursing, pain, and bulls**t over a freaking cat5 cord? ...and head meets wall once again...
    sigpic
    (Insert witty quote here)
    • pentium
      • Mar 2006
      • 2778
      Confirmed. It is the network cable.
      All but two of the wires have a resistance above 1000 ohms. It's not enough to make the system and switch think there is nothing connected but it was enough that whatever passed through the lines never made it from point A to point B.
      Looks like It's finally time to invest in a spool of decent cable and a connector kit. I'm running at least a half dozen different types and brands of network cable as it is and the mice have done a number on all of them so there's splices all over the place.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • Wizard
        • Mar 2008
        • 2296
        #63
        Mice? You GONNA have to find all the openings and repair them. And keep food sources away. I have this same issues at my tv shop, once in awhile when first frost hits. I kill-trap them with snap traps. Usually every 2 years or so.
        Be careful with droppings and urine. Yes, spool of cable and plugs, GOOD tool to crimp/cut and prep with.
        Cheers, Wizard
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          only rodents in my house are my pet rats. most of my lan cables die when the plug clips break.
          glad that was the problem.
          sigpic
          • pentium
            • Mar 2006
            • 2778
            No, the mice problem was two years ago, otherwise I would of been a bit more concerned.
            Lol, a good majority of my clips came off years ago and the cables are now held in place by tape.
            Find Nedry!
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i have a usb 1.1 ethernet adapter with a bad LAN socket... i epoxied a cable with a bad clip in there, works great...
              sigpic
              • harp
                simple win network with optimization issue
                by harp
                simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                06-23-2025, 11:01 AM
              • larrysito111
                msi ms-1543 gp66 leopard 11uh-684uk ms-15431 ver2.0 gpu issue- like driver error
                by larrysito111
                the laptop has a wierd GPU problem
                the GPU is there when you start the laptop and has the yellow exclamation mark in control panel
                when you try to reinstall the GPU you install the driver and all OK
                but when you restart same thing (the GPU is there when you start the laptop and has the yellow exclamation mark in control panel)
                anyone has any idea
                some are telling that the bios need to be downgraded
                i did try to re-flow the GPU twice just to be sure but no change at all
                so bios i think best option....??...
                11-25-2024, 04:34 PM
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
