CPU Cooler fan mod?
  • Phaihn
    • Jan 2009
    • 842
    Re: CPU Cooler fan mod?
    Originally posted by bgavin
    Those are excellent temps.
    What is the room ambient?
    My gripe with cross flow fans is the lack of cooling on the VRM.
    This violates the Intel design spec, which requires cooling for the VRM.
    I bought an IR temp gun, just so I can monitor VRM temps on all the boards I service. Quite a nifty toy.. you shine it everywhere, and it tells you the temps.
    My wife wanted to take it out for her Ghost Hunter night with the girls, but I said no. The last thing I need is for one of my nice toys/tools to get screwed up at a party.
    If you run boards with heat pipe cooling to the VRM, i.e. Gigabyte UD3 boards, the downdraft becomes a non-issue.
    Uh not sure i dont have thermonitor in here but it was realy cold when i woke up this morning.
    uh VRM that space around the CPU with all the caps?
    i have a fan blowing air into my room and it start cooling down at night time.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
    • Phaihn
      • Jan 2009
      • 842
      My Computer.
      • Phaihn
        • Jan 2009
        • 842
        Wont be doing much more glue gunning till i get a new one mine blew up.
        My Computer.
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          I use to have a cheap hot glue gun, until the wires inside the handle shorted out. That was a experience.
          Now I just have a lot hotter, larger Northern Tools hot glue gun, still a cheapie but at least the wires inside this one are thicker and shielded.
          • Phaihn
            • Jan 2009
            • 842
            thats what happend to mine.
            My Computer.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              i had to re-solder one in my shop class. the heater core was shoved into that stanley pretty tight. it had micro-crimps gone bad and un-solderable thin solid wire between the core and the wall cord. i direct-wired it to the paddles on the core and since i was too lazy to go fing eletrical tape, i used duct tape to insulate my joints. the beast still works after the re-wire.
              sigpic
              (Insert witty quote here)
              • Phaihn
                • Jan 2009
                • 842
                Its not even worth the effert i got it at the dollar store i think its time to get a real one. and a soldering iron.
                My Computer.
                • Phaihn
                  • Jan 2009
                  • 842
                  Mod updated. got a new glue gun.
                  My Computer.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    time for my cooler mod
                    i had an old athlon base out of a compaq presario 5000. it was wide but short, perfect for a dell dimension L933r. but i had to make the fan blow out to match the air tunnel, and when i did, the fan mounts in the mille of the edget cought the fan. so, i removed the short edge fin, removed those mount fins in the center edge, and fanned out the rest in the middle, like that zalman cooler with the external fan. pics:
                    original cross-section of extrusion. see the screw-slots are higher than the rest? thats what was catching the fan.
                    what i did to fix the issue
                    another view of my handywork
                    what it looks like with a fan on.
                    i havent tested the cpu with this on. we will see...
                    sigpic
                    • Phaihn
                      • Jan 2009
                      • 842
                      nice
                      My Computer.
                      • Ede2001
                        I am looking for a wiring diagram or boardview EVGA GTX 780 Ti SC w/ ACX Cooler
                        by Ede2001
                        I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.
                        08-26-2025, 03:14 AM
                      • BleedCap
                        OLD Socket 478 custom bracket + NEW generic cooler
                        by BleedCap
                        I already posted this on vogons.
                        Its a 3d printed custom bracket for socket 478.
                        I used this AM4 bracket as a base design.
                        Its to be use with cheap generic clip based cpu cooler.
                        Reason for doing this is:
                        - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                        - New generic cooler is cheaper and can use bigger fan (less noise)
                        I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                        The processor that I was using is P4 2.4Ghz prescott....
                        11-05-2023, 08:09 PM
                      • edugimeno
                        Wine cooler flickers at startup and doesn't cool enough
                        by edugimeno
                        Hi there!
                        I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
                        Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
                        Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
                        When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
                        03-01-2025, 04:51 AM
                      • KYBOSH
                        Wine and Beverage Cooler Control Board Repair Attempt
                        by KYBOSH
                        Trying to a fancy Wine and Can Beverage Cooler which wasnt working.
                        Model number AWBC242GGFD
                        Previous owner states that it needs a new motor.
                        When plugged up you hear a quick chime from the PCB alarm but it quickly dies away (trails off actually) and there is no sign of life from the unit at all.
                        I pulled out the main control board to give a look.
                        Fuses checked out okay. All diodes except one checked out. It was reading in both directions so I pulled it out of circuit and checked it again but this time it read good.
                        07-18-2024, 11:52 PM
