RAID5 failure: 2 bad HDD's at the same time
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: RAID5 failure: 2 bad HDD's at the same time
    No, not all of my contents are lost. I was able to borrow another similar NAS. Over Prime Day on Amazon I've ordered 4 new HDD's. Plan is to "replace" the old raid with a new raid. Basically the old raid goes into the borrowed NAS. My NAS is getting all new drives then copy everything back.
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Perhaps you see why I have TWO of every piece of hardware?
      If you feel ambitious/inquisitive, you may want to keep the RAID drives (after you've returned the borrowed equipment hosting them, presently) and "play" with some of the RAID recovery tools that are available. Your data will already have been recovered so the drives' contents are "disposable" (?). I.e., you can play with them (and software recovery tools) without risk of LOSING anything.
      That could give you a head start if you find yourself in a similar situation at a future date (i.e., you will KNOW that it can be done and HOW to do it -- instead of HOPING it can be done and stressing over HOW to do it!)
      Interesting experience, eh?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        I am building a new RAID now. Coping files like stupid! Well I am not sure if Iam going to play with the old RAID drives, since they are still in warranty and I like to get them replaced if I can. I didn't go for a new NAS. I just went for new HDD's. Maybe I look for a new NAS later in the fall.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          You might want to consider setting up the drives as JBOD and using some number of them "offline" to hold backups.
          RAID is good for enhancing throughput (RAID0) or enhancing availability -- sort of like ECC RAM enhances the availability of data stored in "memory" (but, you wouldn't RELY on ECC RAM for long term storage/backup).
          If you can tolerate the NAS (as JBOD) throwing an error from time to time and using that to prompt you to drag out the "backup", this may be a more effective use of the platters. Your AVAILABILITY goes down (cuz the data wasn't reliably present when you wanted it) but your DURABILITY goes up (cuz the data wasn't lost!).
          I'd still advocate playing with some of the recovery tools just to see if you'll have a fallback "out" in the future... (some vendors just roll a Linux distro into their appliances; others reinvent the wheel -- or, deliberately obfuscate some standard implementation just to tie you more closely to them)
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8327
            This is the idea I have for later. I am going to upgrade sooner or later my NAS. So I going from a 4 bay to an 8 bay NAS. Run a 6 drive RAID 6 and with the other 2 bays two large capacity HDDs on JBOD.
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              #26
              I'd still question the appropriateness of ANY RAID. Remember, all it provides is AVAILABILITY, not DURABILITY. The extra drives might be better used in another configuration (or even "kept cold")
              I've set up RAID on my SAN (and only on my SAN) because it essentially provides "C:" for the many virtual machines that are stored on it. When I activate a VM, I don't want to risk the VM hiccuping because of a disk error (e.g., a corrupt binary or otherwise unreadable file). But, I don't rely on the RAID to preserve my data any longer than that particular "session" (if the array crashes just as I log off, I don't care -- I'll see which drive(s) have failed, replace them and then reinitialize their content from my archives).
              • Stefan Payne
                • 1267
                Well, it also, in theory, should help against one drive failures.
                The Problem is that if one drive fails, another one shortly follows...
                And you have to know the advantages and disadvantages of RAID and the RAID Levels. And that if you have a 4 Drive RAID5 with 4 drives of the same type, the wear might be similar on all of them, so they might fail in short succession.
                But RAID is _NEVER_ a backup. And must not be seen as such...
                Well, RAID1 maybe, kinda...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  No, RAID1 is not backup, not any more RAID3, RAID5, or even RAID6.
                  An off disk backup will protect you from rm -rf / . RAID of any level will not protect you.
                  There is something to be said with versioning filesystems as a type of backup. Coupled onto some sort of redundant RAID (i.e., not RAID0), this however does classify as a weak backup system. Still does not protect you from metadata loss of the versioning filesystem.
                  I've been contemplating a versioning filesystem, but still will need to snapshot them to another disk set. Currently I only snapshot my RAID5 to another RAID (RAID1, incidentally) -- up until the capacity of the RAID1 gets exceeded...then it's time for a new disk...or a file purge...
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    #29
                    ANY "backup" protects you (there's a reason tape is still used!).
                    And, the example suggests the user may have CARELESSLY typed "rm -rf". Had he intentionally (or unintentionally/carelessly) done any number of OTHER things he could still lose data.
                    Change one line of code in a program -- then, try to remember WHICH line it was and what the original version happened to be!
                    Crop that photo of your kid's birthday party -- and then try to recreate the imagery that was lost!
                    Boost the gain in an audio file (so parts peak above 0dB) and then try to recover the original signal. Or, attenuate it and try to re-boost it, later, without dragging the noise floor up in the process.
                    RAID (except 0) gives you availability -- it makes the data stored more accessible in a variety of adverse conditions. Just like ECC helps make RAM data available in adverse conditions.
                    • Stefan Payne
                      • 1267
                      RAID protects against drive failures, kinda...
                      But you need to know the disadvantages or the effect it has on the other drives!
                      For example, if you have a 4 drive RAID5 and one drive fails, you can still work.
                      But if you have 4 identical drives, chances are the other 3 are also on their last legs and will die soon as well. As the Wear and Tear on all drives is similar...
                      So you need to update your backup ASAP, get 4 new drives (or if its older, you might be able to get 2 and go for RAID1 or 3 Drive RAID5 or 4 Drive RAID6 instead) and copy the content of the RAID to the new storage.
                      The old RAID you either keep for safety/emergency Backup or you destroy the drives. But you must not rebuild the array if its older than a couple of weeks...
                      if you make it new and after a week, one drive fails, you can think of replacing the disc and rebuilding the Array...
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8327
                        Right now I have 2 RAIDs. A Raid 5 and a RAID 10. We will see how that goes.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          #32
                          Nothing "wrong" with using RAID. My SAN has four 6-drive RAID6's in it. As I'm primarily using it in a R/O application, the "write penalty" doesn't come into play.
                          The real issue is NOT relying on it to provide your (sole) backup!
                          • titomno2
                            Gaming Laptop Zephyrus S17 TFT not detected every time !
                            by titomno2
                            Hi guys,
                            I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                            So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                            On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                            Then the screen won't work for a long period of time.
                            If I wait 1 or 2 hours it work again most of the time.
                            When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                            01-19-2025, 08:27 AM
                          • flat-earther
                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                            by flat-earther
                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                            So I need to connect another battery in...
                            06-08-2025, 02:00 AM
                          • OscarAV
                            HP Pavilion dm4-1065dx long time to get the power led on
                            by OscarAV
                            I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
                            I have made a quick search for my laptop but I have not seen anything similar.
                            I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
                            09-23-2024, 05:53 PM
                            High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
                            I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
                            This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
                            If it cycling on and off constantly then it is the bulb itself that is the issue
                            06-03-2023, 05:24 PM
                          • EvazX
                            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                            by EvazX
                            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                            However, after some time, the replacement motherboard...
                            08-25-2025, 06:09 PM
