DLT drive write errors.
  • pentium
    • Mar 2006
    • 2778
    I bought this internal VS160 DLT drive (rebadged as a Tandberg Data VS160) almost a month ago and when I first got it, I installed it, loaded the drivers and ran a backup and it went off without a single hitch. I then set the server to run a complete system backup cycle in the first of every month and left it alone.
    So the first comes around and when I get back from work I check it and...I got a read error about four minutes into the backup.
    I tried again. Went a little further and then gave a read error.
    I then tried another tape. It again gave a read error at another random time.
    I assumed that while the CLEAN light was not on that it might still be dirty so I loaded the cleaning cartridge in and ran a cycle and then tried another new tape (so now I'm on my third VS160 tape) and again, I get a read error at a random time.
    It's not having issues with any particular files and between the first time I used it and now it had been in the server (which run 24/7) with a tape loaded in it, doing absolutely nothing. I see no reason at all why I should be having this unless the tape I had loaded got stuck to the head and there's residue on it that teh cleaning tape did not remove or something. It makes no sense at all and so long as I have no way to back my system up, all my files I added/edited since the last backup are at risk of being lost (and these drives are already almost 5+ years old and have been running non stop for probably their whole life).
    Find Nedry!
    Check the Vending machines!!
  • Toasty
    • Jul 2007
    • 4171
    Re: DLT drive write errors.
    What backup software? Compatible?
    Toast
    veritas odium parit
    • Krankshaft
      • Jan 2007
      • 2328
      Blow out the innards with compressed air and clean the tape head with a foam q tip dipped in alcohol.
      Maybe somethings gummed on there?
      Want to rule out hardware before software.
      Does the cleaning tape accept alcohol through a hole or is it a dry cleaning tape?
      • Harvey
        • Apr 2007
        • 264
        After 5 years I'm surprised there's still any life at all left in the read/write heads.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          dirty or scsi termination isues.
          • Krankshaft
            • Jan 2007
            • 2328
            I'm still suprised tape is in use anymore .
            • gg1978
              • Dec 2004
              • 431
              I had a funny issue when i upgraded the tape drive in our old domain controller from a HP DAT drive to a HP LTO-1 drive.. I accidently connected the new SCSI cable that came with it, that had LVD termination, to the place where the old tape drive was connected which was an SE connector.. Funnily enough, it would detect the tape drive, and even read data correctly, but writing it hated.. After i moved the cable to the LVD connector, it worked perfectly..
              What kind of SCSI card are you using, and with which OS???
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                iirc the vs160 is lvd.
                • pentium
                  • Mar 2006
                  • 2778
                  So the answer is an alcohol soaked q-tip possibly?
                  I'll haee to go buy more q-tips an rubbing alcohol but I'll give that a try.
                  How could the heads be worn out?
                  I have seen QIC-150 drives still in use that still run fine and they are WAY beyond their prime.
                  Find Nedry!
                  • pentium
                    • Mar 2006
                    • 2778
                    Hmm. That's odd.
                    I was forced to reboot the server last night and after that was done I tried again for the heck of it and it completed the backup with no problems.
                    I guess something on the bus had to be reset.
                    Find Nedry!
                    • ahmedtou
                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                      by ahmedtou
                      help me please
                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                      I will share all the details with you, including the disc information.
                      Code:
                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                      Current Profile: BD-R
                      Disc Information:
                      Status: Empty
                      State of Last Session: Empty
                      Erasable: No
                      Free Sectors: 12,219,392
                      Free Space: 25,025,314,816 bytes
                      Free Time: 2715:27:17 (MM:SS:FF)
                      Next
                      Yesterday, 08:49 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • tarikabak
                      PALIT RTX 3060 VRAM LOCATION
                      by tarikabak
                      Hello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
                      mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
                      Memory Errors on
                      Read Error Count: 0
                      Write Error Count: 410022
                      Unknown Error Count: 0
                      === MEMORY ERRORS BY SUBPARTITION ===
                      SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
                      01-13-2025, 09:21 AM
                    • triplefour
                      LG 75UN8570AUD panel issue fixed with tape.
                      by triplefour
                      I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                      add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                      07-17-2023, 10:22 PM
                    • ChaosLegionnaire
                      bug of the month: write caching setting for the hard drive in device manager
                      by ChaosLegionnaire
                      i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                      so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                      10-06-2019, 01:39 PM
