Geforce 6800gt VGA missing red output signal
+ More Options
Posts
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Geforce 6800gt VGA missing red output signal
    That's why I pick them up with a toothpick with a tiny bit of gel flux on it.
    Otherwise... yeah when they fly away, good luck finding them. For me it's even harder, as I have a thick carpet on the floor. It's white (thankfully) and not those off-white or gray carpets that tend to hide everything you drop on them.
    • shabs1985
      • Nov 2019
      • 3
      Originally posted by momaka
      You'll need a soldering iron with a sharp tip. The tip doesn't necessarily need to be small. It just needs to be sharp. Chisel and bevel-shaped tips should be easier to use over regular conical/pencil. The one on my iron is spoon-shaped (cheap copper tip that wore into a spoon over time, but it works great for SMD stuff.)
      As for the inductors... just put piece of wire in their place or a 0-Ohm SMD resistor. It's not an ideal solution (may or may not cause slight color imperfection or possibly noise/blurriness at very high resolutions), but it will get the card working, at least.
      Will I have to solder 4 wires for the two missing inductors?
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        If you can, YES.
        I think only two of those are really needed to get an image, though (two of them are simply grounds.) But again, skipping the two grounds on those may deteriorate the image even further.
          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
          10-02-2024, 08:52 AM
        • gurj1979
          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
          by gurj1979
          Hey guys.
          Need help with this one.
          Fan not spinning due to missing PWN Fan signal.
          Also 5 seconds from powering up it freezes, unless in BIOS.
          But as soon as Windows starts to load, it will freeze.
          CPU is COLD / Room temp when it freezes.
          I've replaced the CPU, same problem.
          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
          Replaced fan - same problem.
          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
          08-19-2024, 05:22 PM
          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
          10-02-2024, 07:51 AM
          NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
          The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
          10-01-2024, 01:54 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
