Linux Mint 19.1 Cinnamon Artifact issue
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I've been diddling around with Mint 19.1 Cinnamon...and have gotten a strange artifact issue.
    It's being pretty mild there, many times its rendering windows illegible.
    System specs are
    X8DAL motherboard w 2x Westmere CPU's
    24gb RAM
    Quadro FX5800 4gb
    I thought at first the GPU was simply bad, so I swapped it for another (I have several of these), result was the same. I then booted it into Windows 7, everything is hunky dory within Windows, but FUBAR with linux....I know, go figure....but its a bit annoying.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • CapLeaker
    Leaking Member
    • 8327
    Re: Linux Mint 19.1 Cinnamon Artifact issue
    I've got the same thing once in a while only on one computer. It isn't there all the time on mine. On my laptop it works fine as kind for some reason.
    The computer that has the same artifact is a ASUS Maximus VIII, Intel 6600k, 16GB Ram, SSD and a Nvidia 1050, dual screen setup. It happens on my second screen, while I scroll something on my first screen.
    The Asus laptop which Mint works fine on is a 4770K, 20GB Ram, SSD, Nvidia 860m.
    What gives?!
      • 31201
      who's driver, Nvidia, or the open-source one?
      • CapLeaker
        Leaking Member
        • 8327
        Nvidia drivers on mine.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          It's whatever came with Mint. I haven't tried others <yet>....Hard to imagine an embedded driver for such an old card being buggy.....but I guess there's a reason it's 'free'.
          Team : 49813
          Join in!!
          Team Stats
          • CapLeaker
            Leaking Member
            • 8327
            probably the open source driver.
            the last update from Manjaro killed the USB 3 port on my other lappy. Ugh!
              • 31201
              usb3 uses a microcontroller for speed,
              they need firmware.
              same as the nvidia problem, most distro's cant/wont include 3rd party binary's in the iso's - you have to add them after install.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I'll try the nvidia driver and see what that does...
                Team : 49813
                Join in!!
                Team Stats
                • CapLeaker
                  Leaking Member
                  • 8327
                  NVIDIA driver didn't help me any...
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16958
                    In 'driver manager', I switched it from the default open source driver to nvidia driver 340.107, that seems to have got it....but I'll diddle around with it some more before I call it cured.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Hondaman
                      Japanese language -- Win7 or Linux Mint?
                      by Hondaman
                      I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                      Does anyone have experience...
                      09-12-2025, 04:32 AM
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      🛠 Original Issue
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • ugamazing
                      by ugamazing
                      12-17-2024, 07:05 PM
                    • shahnld
                      Lenovo legion 5 pro startup issue
                      by shahnld
                      Good day Experts
                      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                      08-24-2025, 12:31 PM
                    • ahmarzo
                      Acer laptop battery draining issue
                      by ahmarzo
                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                      08-02-2025, 06:39 AM
