HDD bombed - I need your guys's help
  • weirdlookinguy
    • Sep 2007
    • 1638
    So I'm on a family trip visiting relatives, and of course I get sucked into fixing everybody's goddamn computer while I'm over here. Anyhoo, I'm working on my aunt's iPod, I loaded it up with tons of music last time I came over here. After I left, she wanted more music so she took it to some moron who claimed to be an expert with iPods. She didn't see her iPod for a month, and when she got it back there was no music on it. It's been that way for a few months. When I plugged it in to my laptop, iTunes would crash and in windows explorer there were a bunch of empty folders with gibberish names when opening the drive. I figured whatever had happened to this iPod, the file system had been corrupted pretty badly. I tried formatting it but it says it is write protected. Now when I plug it in, it says the disk is 2TB even though it's only an 80GB. It won't format using the HP USB Format Tool - it says it is write protected.
    The iPod won't boot. It keeps restarting, because it can't read anything off its own hard drive. I have to force it into Disk Mode to get it to show up as a drive when plugged into my laptop.
    I'm at my wit's end here. All this thing needs is a good, zero level format so that the file system can be rebuilt. However, because of the write protection, I can't do that. Can you guys help, or recommend a good tool that can completely bomb this drive and make it readable again?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: HDD bombed - I need your guys's help
    try using "computer Management" and go to disk management
    try that, and then see about reloading the firmware
    sigpic
    (Insert witty quote here)
    • weirdlookinguy
      • Sep 2007
      • 1638
      Tried both of those options - reloading the firmware, or "restoring" it via itunes just sets the stupid thing into a loop where it keeps trying to boot and restarts. Disk Management didn´t give me any crap about write protection and seemed to be working, but then at the end it said the format could not be completed. It seems to think that the drive is 16,483GB or something crazy like that. Opening the drive in explorer brings up a message that says that the drive needs to be formatted before it can be used, but a format fails of course.
      Any ideas anyone?
      • lucky13
        • Aug 2007
        • 412
        From what I've came across, if the drive is reporting the wrong size, it is finished. There is no software to fix that. You need to get a new drive.
        9/10 times, there is physical dents to the iPod when the drive fails. These things are pretty fragile if not dressed with protection.
        I normally yank it out and connect to a ZIF to IDE adaptor and use HDTune on my PC to map the bad sectors. Sometimes I find only several bad sectors and I use PM to partition out the bad area. Unfortunately, iTunes will wipe whatever your partition you've set it to so the drive is only good for storage.
        • Krankshaft
          • Jan 2007
          • 2328
          Sounds like the Ipod expert dropped it and crashed the HDD .
          I've opened these units from the Nano to the larger Videos.
          HDD replacement isn't that hard as long as you get the disposable nylon opening tools so the thing doesn't look like it was opened with a pry bar .
          Compared to the 1st gen Nano (the first Ipod I opened) the video was as easy as hell afterward.
          The drives are around 30 bucks or so well worth it IMO.
          • Toasty
            • Jul 2007
            • 4171
            Perhaps:
            http://www.troublefixers.com/remove-...-card-or-ipod/
            veritas odium parit
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              2 choices:
              1: trash it
              2: it until it is gone for good
              if you dont understand, then maybe this link will help:
              http://www.innfusion.com/blogimages/Brick.jpg
              sorry bub, but it that moron commited iMurder , a class i iFelony rsutiong in a trip to iJail
              sigpic
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Or... he still has your Aunts working iPod back at the shop... and gave you one that was already dead.
                Ludicrous gibs!
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  wouldnt that be funny ...
                  and sad
                  sigpic
                  • NxB
                    • Feb 2009
                    • 1595
                    Replace the HDD, sorry.
                    • weirdlookinguy
                      • Sep 2007
                      • 1638
                      I figured it was fucked. Thanks guys, needed a second opinion.
                      I honestly don´t know if I´m gonna tell her about the new drive option, I hate iPods and I´m especially tired of fucking around with this one.
                      Merci beacoup mes bon amis,
                      -weird
                      • NxB
                        • Feb 2009
                        • 1595
                        Ebay.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          sony walkman.
                          sigpic
                          • gdement
                            • Jan 2007
                            • 690
                            If you can get the drive out, then there are utilities that can reprogram the size and also the transfer rate. I've done that with Hitachi/IBM, but other manufacturers may have something similar.
                            Probably doesn't matter though, the whole firmware is probably trashed, not only the reported size. I doubt the guy who ruined it really just edited the size to 16TB. I think you're right to give up on it.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              dont buy ipods they are fragile, overpriced, and lock you into itunes hell.
                              there are lots of good non-apple mp3 players online... save some green and get a better product while saving money
                              sigpic
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                I just have one of those cheap 8gb creative zen's. It has a large screen, built in radio (uses the headphone wire for a antenna) plays videos, and has a SD card slot that accepts high capacity sd cards.
                                You can even get one of those super cheap tiny mp3 players and put rockbox on them. It allows about anything with a color screen to play video.
                                • weirdlookinguy
                                  • Sep 2007
                                  • 1638
                                  I like iPods. I think they are well designed players with decent build quality, and they aren´t any more fragile than any other comparable mp3 player. I wouldn´t buy one for myself, but I think they are great players for your average, not-that-tech-savvy consumer. They have also done a lot more to advance portable music than any other mp3 player has. Don´t talk shit on iPods just because it´s the cool thing to do.
                                  I do agree, however...
                                  -That they are overpriced (not as much now as they used to be, but still)
                                  -I don´t like being locked into iTunes
                                  -Not upgradeable
                                  Personally, I use the most excellent Nokia 5310 XpressMusic for my phone/music duties. Tinyass, slim, sexy looking little phone with excellent reception/call quality, great battery life, plays all my music, and takes CHEAP, EASILY UPGRADEABLE miniSDHC cards for storage. It has a REGULAR 3.5 JACK FOR HEADPHONES JUST LIKE A DEDICATED mp3 PLAYER! And the sound quality is indistinguishable from any dedicated mp3 player.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    i could never afford an ipod.
                                    sigpic
                                    • weirdlookinguy
                                      • Sep 2007
                                      • 1638
                                      And your point is?
                                      • ChaosLegionnaire
                                        bug of the month: write caching setting for the hard drive in device manager
                                        by ChaosLegionnaire
                                        i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                                        so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                                        10-06-2019, 01:39 PM
                                      • Norrecito
                                        iPod nano G3 - alternative soldering point for the white battery wire
                                        by Norrecito
                                        A friend of mine gave me an iPod nano G3 to see if I can fix it for him.
                                        The device had a faulty battery and he tried to replace it but failed. In the process he managed to pull off the pads that corresponds to the white battery wire (marked with a red circle in the images)....from both sides of the PCB. Fortunetely he didn't damage anything else.
                                        This is usually an easy fix HOWEVER, on the PCB, I see no traces coming from the VIA and after searching the internet, I've found no schematics nor boardview for this device. With the pads gone from both sides I seem...
                                        09-07-2024, 03:54 AM
                                      • vbogoev
                                        Lenovo S6000 won't turn on. Data recovery needed.
                                        by vbogoev
                                        Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
                                        Code:
                                        [PWRAP] pwrap_init_preloader
                                        [PWRAP] pwrap_init
                                        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
                                        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
                                        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
                                        [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
                                        [PMIC_WRAP]wrap_init pass,the return
                                        06-20-2023, 06:36 AM
                                      • alphabetty
                                        novice user attempting first BIOS write on ASUS laptop
                                        by alphabetty
                                        Hello first post!
                                        Ok so after an (ASUSTek) optional Windows update, my old ASUS E403NA laptop rebooted and froze in the BIOS menu screen and was unresponsive so after about 30 mins I powered off and back on again. Now i just get a power LED and a black screen, I have tried all the basic suggestions and all the suggestions on the ASUS site, spoke to ASUS support who said I will need to pay for an RMA.
                                        The laptop is worth €50 so I won't be doing the RMA at god knows what price.
                                        So I have seen some videos where people have reprogrammed the BIOS...
                                        03-07-2024, 08:31 AM
                                      • CapThatBrass
                                        RT809F Chip Write Failure - Winbond 25R256JV
                                        by CapThatBrass
                                        I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
                                        I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
                                        The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
                                        10-04-2022, 11:56 AM
