Bios settings for add in cards
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I just had and interesting turn of events with my Junk Dell P4. The output sound jack on the rear of the mobo is bad so I added a Sound Blaster Live card to get around this problem. I tried to burn a few movies the day before yesterday but I kept getting error code = 122 during the burn using DVDFab5 and 6. I uninstalled and reinstalled all my burning progies but I still kept getting that error. So I called my brother to see if he could solve my problem, and he did. The first thing he said was did you turn off your onboard sound chip in your BIOS? I'm like no I didn't. I thought it was a smart bios that would see that there was and installed sound card, and use it by default. Well I went into the bios and turned off the onboard sound chip, and the error =122 went away. Life is good! At least I now know what error =122 means! Errow =122 means "Junk Parts Screwed Up Again!"...LOL
    Mark Twain
    John Paul Jones
    Rod Serling
  • pentium
    • Mar 2006
    • 2778
    Re: Bios settings for add in cards
    Makes logical sense.
    Whenever I setup a system I always go through the BIOS and switch stuff off that I don't need (like the onboard sound as I have an Audigy card installed). I find that it frees up any I/O that the system might use for other stuff as well as helps take care of headaches when troubleshooting and in one case, overclocking.
    Find Nedry!
    Check the Vending machines!!
    • NxB
      • Feb 2009
      • 1595
      I've run 2 sound cards for recording before. Onboard was on too.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        some boards don't like that due to irqs. check irq settings in bios. check for a disable jumper on the board.
        edit: also remove the onboard driver- that will f*** things up in windows sometimes. at the very least, it removes some bloat from the machine
        just for our info, what audio chip is on the board (not sb live) that way we know what chip to be careful of
        sigpic
        (Insert witty quote here)
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • cr4zychriss
          by cr4zychriss
          • Rebrand: PC Specialist
          Yesterday, 04:04 PM
        • YG007
          Asus BIOS How To Reset To Default Settings?
          by YG007
          Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
          I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
          06-05-2023, 08:22 PM
        • pirati
          by pirati
          10-27-2025, 04:20 PM
