Weird SSD Issue
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Weird SSD Issue
    If interrupting a secure erase causes passwords, it's on me. After dban fought with it for 10 hours and said there was still 8 days to go, I just shut it off....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Weird SSD Issue
      That explains a lot...
      From what I'm reading the utility that was used set a temporary password which was never cleared.
      Topcat, what utility did you use to issue the secure write instruction? Once I know that I might be able to go somewhere. In the mean time, I'll try some more common "defaults" and see if I can crack it.
      sigpic
      (Insert witty quote here)
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16959
        Re: Weird SSD Issue
        it was DBAN
        Team : 49813
        Join in!!
        Team Stats
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: Weird SSD Issue
          it was DBAN
          From what I'm reading DBAN doesn't "secure erase" using the ATA instruction... and also the methods it does use aren't recommended for SSDs (due to the way SSD's work compared to a rotating HDD- the methods will kill the wear leveling lifespan among other issues). For SSDs I'm reading the best option is the boot utility made by the SSD OEM (in this case, the OCZ utility listed for this model), which will "secure erase" the drive using the built-in "secure erase" function as per the ATA standard. The setting of a temporary password is part of the standard which is to protect against half-erased drives being read after a malicious party kills power during the erase.
          Did the drive work at all before you tried to DBAN it? Or was the DBAN an attempt to fix it (which probably froze due to being locked out)? Or did they add an SSD-rated "secure erase" function to DBAN that my research isn't showing? OCZ drives locking themselves like this isn't unheard of but the usual fix of secure erasing from the OCZ utility didn't work for me.
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            Re: Weird SSD Issue
            No, it was not working right when I zapped it with dban. I pulled it out of a system, cloned it with 'clonezilla'. Plugged the new larger target drive into the PC, it booted right up. I put this drive into a laptop I was going to use it in.....BIOS saw it, but windows installer was unable to access it. Couldn't format it, add/remove partitions, etc.....downward spiral since. I even put it back in the system it came from, no bueno....
            Team : 49813
            Join in!!
            Team Stats
            • junktv
              • Nov 2010
              • 3065
              Re: Weird SSD Issue
              Not sure if relevant but just had a standard drive that wouldn't show on 7 pro. A WD mypassport 1tb for mac. Using linux mint 13 maya xfce 4 it seen it and could format it every which way. Windows wouldn't see it until I installed the WD utility and formatted it with it.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: Weird SSD Issue
                May be a toasted controller then... IDK. Will try a few other things. Seems like OCZ (at least of that era) is unreliable junk...
                sigpic
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16959
                  Re: Weird SSD Issue
                  The first I've heard of that....I used dozens of them in the last 10 years, this one was the first casualty....and it was fine until removed. No idea what went wrong. Whatever happened to it, I probably did it... COntroller is fine, it was just an ICH9 onboard a RoG Maximus Formula....the system is hunky dory with the new one that was cloned off this dead one, and there were no issues prior, just upgraded to a larger one. FWIW, it has ran 24/7/365 for 3~4 years....
                  Team : 49813
                  Join in!!
                  Team Stats
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Weird SSD Issue
                    I meant the controller on the SSD itself, not you mobo!
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: Weird SSD Issue
                      She's bricked... hdparm keeps kicking back "sg_io bad/missing sense data" errors whenever I try to do anything. Tried on several systems to no avail. From what I read this indicates a failed SSD controller... *trashcan*
                      sigpic
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16959
                        Re: Weird SSD Issue
                        Ohh well....was worth a shot. I wonder what caused it...
                        Team : 49813
                        Join in!!
                        Team Stats
                        • brethin
                          • Dec 2008
                          • 1907
                          Re: Weird SSD Issue
                          Ratdudde drop it in a envelope and send it to me,. If I get it working I'll send it back to you for free. I have a few tools for OCZ I can't share because they are tied to a certain machine but may be able to help you out.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: Weird SSD Issue
                            PM sent... but if anything send it back to topcat if you get it to work since it was his to start.
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16959
                              Re: Weird SSD Issue
                              Nah, its yours.....
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #35
                                Re: Weird SSD Issue
                                One issue... I don't have either the user or the master password! Both methods seem to require one to know the password already... which I don't since it wasn't set by a conscious person.
                                Topcat didn't set it... it set itself due to a glitch of some sort?
                                Bricked?
                                If the drive is in "frozen" state (ATA command) and sleeping the drive does not unset it then you can try pulling power to the drive for a second or two, that should clear it
                                (Frozen status is enabled by the PC BIOS during POST).
                                However if the drive is encrypted then you first need to clear the encryption key, this is done using a PSID revert, tools for this should exist if the drive supports it.
                                And the password to do so should be printed on the drive itself.
                                However a quick Google seems to indicate that this SSD does not support encryption, in that case the issue can not be with the encryption key being set...
                                • SuperJames
                                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                  by SuperJames
                                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                  Specs
                                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                  Backstory
                                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                  10-23-2023, 04:09 PM
                                • ugamazing
                                  820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                  by ugamazing
                                  So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                  1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                  2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                  04-10-2024, 08:06 AM
                                • lukkihapsi
                                  Asus Vivobook X515JA Weird Boot Issue
                                  by lukkihapsi
                                  Asus Vivobook X515JA Laptop
                                  Issue :
                                  Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                  Tried :
                                  Cleaned inside for dust, applied fresh thermal paste. No Change!
                                  Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                  Removed Internal SSD. No Change!
                                  Updated BIOS to latest version. No Change!
                                  Removed battery and pressing power button for 1 minute. No Change!
                                  Weird Part :
                                  Upon turning laptop ON, screen lights up - stays black,
                                  I...
                                  07-07-2025, 12:07 PM
                                • tommygun26
                                  Hp 6510b weird issue
                                  by tommygun26
                                  Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                                  02-26-2023, 06:00 AM
                                • Stephen
                                  A2141 Weird Issue But works
                                  by Stephen
                                  Got an A2141 MacBook Pro 16" computer turns on however the track pad clicks but the keyboard has no life, NO LIQUID DAMGE whatsoever. Trackpad does click but the OS loads but the trackpad won't move the cursor, the keyboard is unresponsive. I replaced the cable and the trackpad to see if that was the issue but it was not, I went to see if the CAPS LOCK would turn on but it does not. Any indication what this is? I went and tested the lid sensor but nothing else. Battery holds a charge, fans spin normally, and lcd is good. I can use external mouse and keyboard without issue....
                                  05-06-2025, 10:23 AM
