OT (?): storing disks
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    I keep a lot of offline media. Lately, the number of 3.5" disks has been increasing at an alarming rate (I place limits on the sizes of spindles that I will support so this means my data density is "fixed", per "disk unit").
    I keep many of the drives to which I may need frequent access in SAS shelfs. But, there's a lot that are just sitting on a closet shelf (i.e., not accessed often).
    Anyone have any favorite "right sized" boxes/containers that neatly fit say 10 or 12 drives (more than this gets to be a bit heavy)?
    The prepaid USPS "shoebox" is almost a good size for drives in Dell "server sleds" but way too big for bare drives. And, most of the plastic storage boxes (e.g., Sterlite) have rounded corners which make them poor fits for the squared edges of disk drives. So, I figure cardboard is the only real choice...
    • 31087
    Re: OT (?): storing disks
    people i know just stack them 4-5high or on their sides in shelves.
    • desert-rat
      • Mar 2014
      • 4103
      Wal Mart/home Depot have plastic tote bins . You should be able to find some about the rite size.
      • brethin
        • Dec 2008
        • 1907
        I use these sometimes, drive in ESD bag and diag report printout stuffed in with the drive.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Far too many (or, far too little shelf space). I need to put them in boxes that I can place (stack!) on the floor, under a bed, etc.
          I keep at least two copies of everything (music, software, clipart, loops, books/technical reports, etc.). Plus, a copy of every "system image" when I finish projects for clients (so I can restore the system year(s) later when they request some change or enhancement to the design, board layout, etc.)
          I probably have close to 200 drives "in use" (almost 100 "mounted" and ready to spin up).
          Disk space is cheap. But, space for disks isn't!
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            Yes, I took a trip there before posting (hence the "Sterlite" reference). I found a nice little case that can hold 7 drives on their sides (I affix an adhesive label to the side to tell me the size, contents, PoH, etc. so this makes it easy to read ALL of their labels)
            But, the containers have rounded corners, a "bulging" top cover and wide "lips" (maybe to make them easier to carry?) so end up oversized (the drives can slosh around -- not a snug fit). As such, there's a fair bit of wasted space (volume).
            https://i.ebayimg.com/images/g/eCcAA...4RA/s-l640.jpg
            [Obsessed with storing things in as small a volume as possible as "indoor" storage space is at a premium (few closets, no basement, no attic and garage way too hot to store electronics -- let alone risk of black widows, scorpions, etc. crawling into boxes: "Surprise!")]
            I raided the "box dumpster" at one of the local hospitals (it pays to have friends in low places :> ) and found some boxes that were used for some sort of medical supplies (trach tubes?). They look like they will hold 10 drives (on their sides) with a "hinged flap" cover. A bit taller than the drives are wide (risk of that excess heigt being crushed when they are stacked) so I'll have to cut some cardboard to place under the drives -- to bring them flush with the top of the box.
            Then, head back next week to see if they've received a new shipment of whatever the hell was packed in those boxes originally!
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              I have something similar to this, but just one.
              https://www.ebay.com/itm/Hard-Drive-...p2047675.l2557
              used it for some drives lying around. Putting some 2x2.5" in a slot too
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                Ooooh! Yummy! But, dropping $10 for each is a bit pricey.
                My current solution:
                • DynaxSC
                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                  by DynaxSC
                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                  The behaviour is also really very strange, i.e.:
                  • The disk shows always up in BIOS - so it is recognized, so far so good
                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                  02-23-2025, 01:33 PM
                • eccerr0r
                  It's 2025: do you know where your 5¼" floppy drives are?
                  by eccerr0r
                  Oh wow.
                  As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                  Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                  Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                  Weird. Seems the PC drive is having trouble clamping...
                  07-07-2025, 12:49 AM
                • jasakl
                  Panasonic Toughbook HDDs with hard drive encryption - how to reuse them?
                  by jasakl
                  Dear community,
                  i have searched the internet but i dont found a working solution for my problem:
                  I have about 150 hard drives (mostely from hitachi 160gb HTS543216L9SA00) from Pansasonic CF-19 MK3 Notebooks.
                  All devices had a BIOS Password and HDD encryption enabled.
                  Now i try to reuse the HDDs, but i cant format them. I already tried windows Diskpart with argument "attributes disk clear readonly" but it says "cant delete" and i tryed several partition and low level formatters (like partition wizard, AOMEI and Easus).
                  But all of...
                  05-01-2024, 02:41 AM
                • madura2010
                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                  by madura2010
                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                  i checked the connectivity of ribbon=good communication with hard and motherboard
                  changed hard disk and checked=3f0 error persist
                  sata power=+5v available
                  Then checked data capacitors=all good
                  Then checked data lines path connectivity to pch=all good
                  reflashed...
                  03-12-2023, 09:09 AM
                • chth96
                  LG GCC-4521B cannot read any disk
                  by chth96
                  I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                  But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                  And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                  But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                  02-13-2024, 07:31 AM
