New SSD vs. "New" Laptop
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: New SSD vs. "New" Laptop
    Screw lenovo, I've had nothing but headaches with their crap. Dells are a lot easier to service and are far more upgradeable. Lenovo makes it hard to upgrade (like having to replace an entire LVDS cable just to add a bluetooth module, etc); dell makes it a lot easier (plus no wifi whitelists!).
    And that reminds me, that my "Lenovorola" e4, randomly turns the volume down, when idle, but not when playing music on Spotify, LMHO!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • dmill89
      • Dec 2011
      • 2531
      Originally posted by lti
      Dell Precision laptops have Xeon options.
      yep, and the newer ones are BGA just like the i5/i7 .
      • lti
        • May 2011
        • 2545
        Also, every new Dell computer comes with MaxxAudio "enhancements." If you join a meeting remotely, everyone will sound like the teacher from the Charlie Brown cartoons until you turn off MaxxAudio.
        Yes, that happened to me on a Dell Precision.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          MaxxAudio does indeed suck. It can be nice, but from my experience does more harm than good.
          sigpic
          (Insert witty quote here)
          • sofTest
            • Aug 2008
            • 361
            Having just a couple of weeks ago bought a E5470, that you are considering, intended as replacement for the E4310 that I also have owned for six years, a few observations might be of use for you.
            - the E5470 got a chiclet keyboard. Some hate them. I'm still undecided, but I'm probably OK with it. I don't type a lot on this PC anyway. It supposedly is a lot more spill and dust resistant, that might be handy for some.
            - storage expandability on the E5470 are badly documented. The BIOS got support for 3 SATA and one M.2 PCI-e drive, a total of four choices. On the physical side, it's not that simple. There is a 2280 M.2 slot. It is documented that the E5470 is delivered with both M.2 SATA and PCI-e drives from Dell in this slot, so it should be a dual purpose slot. If your computer does not come with a M.2 drive originally, you would need to buy a fastener bracket to use that slot. That accounts for two of the BIOS choices. There is a space for a 2.5" SATA drive, IF the PC does not got the big battery pack AND the dual purpose M.2 are not populated. If your computer came with a M.2 drive, you would need to buy a special Dell cable and bracket to mount a 2.5" drive, in addition to removing the M.2. That's the third option. Totally unsupported by Dell, the WWAN slot have been populated by many with a M.2 SATA 2240 drive. That's the fourth choice. Fine it you do not got or need a WWAN card. Mine does, so I'm investigating putting a M.2 2240 SATA drive or a mSATA drive on a 2.5" adapter, and connect it up to the Dell 2.5" SATA cable, to populate the 2.5" drives lesser space not taken by the long M.2 drive. I would need to fabricate some kind of custom fastener for this solution. I have not found anyone documenting doing this, so it's somewhat experimental. Or I might get a 2.5" stripped of its casing to fit. I've also seen claims that not all models of E5470 uses 4 lines for the PCI-e. It was suggested that the U-processors uses two lines, and HQ-processors uses four. Can't check that myself (yet), as the M.2 2280 in mine is a SATA-model.
            - the E5470 is not that much speedier in general use than the E4310. I seldom max out the CPU my self, even on the 4310s 560M. My E5470 got the 6300U. More important for me is fastish disk IO (nothing spinning would to) and a largeish local storage, as I from time to time uses some large file sets on this computer. My E4310 got 2x240 GB SSD now, but the E5470 will get about 750 GB in some configuration not yet decided. I like dual physical disk configurations, as it is easier for me to swap an emptied storage/work disk than cloning a disk with OS on.
            - you mentioned Minecraft especially, but as I have no gaming interest, I googled it. If I understand correctly, the CPU is most often the bottleneck for Minecraft. You might want to google your current CPU vs. the model you are considering, to see if it might give enough benefits. I don't know how Minecraft utilizes CPUs, so I'm blank.
            - the E5470 got SS USB. That might be fast enough to boot a casual OS from! I'm thinking something like an external SSD with SS USB support. I will probably test it some time during winter to come. Until I've figured out internal storage, I will use an external 2.5" 500 GB SS USB SSD for storage/work.
            - the E5470 got no optical, as is usual for newer laptops. No loss for me.
            - why do I upgrade? More display estate. The E5470 got a FHD display. I have never liked displays with less than 1000 lines (ish). Not 900, and especially not 768 like the E4310 got. My other most used laptops now got at least FHD displays, or better like my Surface Pro 4s. It's time for me to leave that low res technology for my most frequent uses.
            You mentioned future proof. If you got special known requirements coming up, fine, plan for it. Else, no one knows anything about what the future brings, and it's requirements. I tend to upgrade in steps when needed, until it's not practical or cost effective any more. Like the E4310, if I had found a FHD panel upgrade at a reasonable cost, I probably would have upgraded. I did however never find any such upgrade, nor an attempt documented by anyone. I know and trust equipment I have owned a while, but with new stuff there is always a chance of discovering dislikes and problems one didn't have with the old stuff. And there is usually trade offs in regard to loss of features vs. gaining new.
            Anyways, just my 2 cent.
            Be a mensch
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Sounds like I may be better off saving for an SSD and possibly a RAM upgrade. I have an i7 3632QM in my E6430. Specs:
              http://www.cpu-world.com/CPUs/Core_i...processor.html
              I have 8GB of DDR3... 16 would help.
              It uses the HD4000 graphics in the CPU. It has a 1600x900 display.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Also, it does have a couple USB 3.0 ports. I still wouldn't want to use it for an OS drive... not on a laptop, anyway.
                sigpic
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Bit the bullet... and bought an Intel 545s 256GB SSD. I'm in Canada again (another company trip), and Canada Computers had a sale (to match Newegg). Yes, I got raped on sales tax (yay Ontario ) but it needed done, and I had the motivation at the time (along with the tools needed to make the swap, I came prepared.
                  Pictures:
                  Shiny packaging:
                  Apparently live arch sticks support HDMI; here's how I found out:
                  This is what I use hotel room TV's for... otherwise they're brainwash/idiot boxes that I have no use for most of the time. But they do work as a good 2nd monitor and external speaker system
                  Old and new drives:
                  Getting the new drive to run both OS's was fun. The linux part was easy (done it a million times, no sweat)... migrating the windows install was trickier... discovered what "active" partitions are, and once I "activated" the new partitions, I was able to use a windows 7 recovery disk (USB made from the CD ISO) to make the drives bootable from GRUB. All well now... and from the testing I've done, much faster. My disk speeds are no longer the bottleneck as per the windows performance index (went from 5.9 to 6.5, drive speed maxed at 7.9 :P ). And I did novabench it:
                  As for the old SSD, luckily I was able to remove the black trim ring to slim the drive down; it's now in the keyboard base of my Asus Transformer T200TA (as it's too small for any of my other laptops in service to not have the same problem, but too good to toss/shelve). That poor thing only has 64GB internal storage (and that's double what the base model includes ); good thing ASUS gave some provision for expansion.
                  sigpic
                    Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                    09-06-2024, 09:30 PM
                    Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 08:47 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                    Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-07-2024, 06:11 AM
                    Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                    This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
