backup program to restore applications?
  • travistee
    • Sep 2008
    • 68
    Is there any backup software that will make backups of the entire disk including applications.
    I have XP home on a laptop.
    I want to do a new install of XP home (different product key, same XP) on another computer.
    I want to have a backup of the laptop then restore it on the other computer.
    Is there anything that can do that?
  • kikkoman
    • Jul 2007
    • 691
    Re: backup program to restore applications?
    sounds impractical to me because the second computer most likely has a different chipset.
    you'll spend more time tinkering around with drivers (and probably WPA/WGA stuff) than doing a fresh install would take.
    possible - yes, practical - no.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • acstech
      GrumpyModerator
      • Jul 2007
      • 1432
      It depends what your resources are. If you've got a computer running Linux, or able to run a linux live cd, try this:
      1. See here: http://madberry.org/2009/01/clone-a-drive-with-dd/
      a. The source drive needs to be smaller than the destination drive. If not, you can use gparted to shrink the source partition to a size smaller than the destination drive. Afterward, you can expand them back to the maximum size of the drives that they are on.
      2. Obtain (I'm not going to tell you where) the microsoft sysprep utility. This will reset activation and allow you to input a new product key.
      3. Screw around with drivers and so on.
      I'd rather just do the fresh install...
      A man convinced against his will is of the same opinion still.
      • JohnBiggs
        • Mar 2009
        • 13
        Try these
        http://clonezilla.org/
        http://www.partimage.org/Main_Page
        Or more.
        http://www.downloadsquad.com/2008/09...ur-hard-drive/
        And yeah with windows this isn't practical for changing hardware.
        • travistee
          • Sep 2008
          • 68
          Seagate has something called Disk Wizard which is a limited version of Acronis.
          Its free.
          It will work if you have at least one Seagate or Maxtor drive.
          I'm going to use that.
          I'll do a repair install of XP on the cloned disk.
          • Toasty
            • Jul 2007
            • 4171
            Agree with kikkoman & acstech - Do the clean XP install. If it was an IDENTICAL system, then you could.
            Do the new XP install. Use the XP Files and Settings Transfer Wizard to move your data. Start->All Programs->Accessories->System Tools
            See: http://technet.microsoft.com/en-us/l.../bb457074.aspx
            Toast
            veritas odium parit
            • travistee
              • Sep 2008
              • 68
              That will only migrate the files and settings, not the installed programs.
              • Toasty
                • Jul 2007
                • 4171
                Never said it would. Said "...to move your data"
                No sense repeating what others implied and the link to MS will explain what will and will not be copied.
                veritas odium parit
                • bgavin
                  • Jan 2007
                  • 1355
                  Ghost
                  • travistee
                    • Sep 2008
                    • 68
                    I used seagates disk wizard. Its a version of Acronis.
                    Free if you attach any maxtor or seagate drive to it.
                    Works fine.
                    Repair install worked fine.
                    Now my desktop system thinks its a sony vaio laptop.
                    Just had to uninstall the sony stuff that only runs on sony.
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      i was using acronis today again. i do like it.
                      has some dangerous option though to clone the disk and erase source disk...
                      unfortunately i wanted to clone a win2k server boot disk from a 120gb to a 250gb. i forgot to apply the largelba registry patch before cloning. so i get inaccessible boot disk when i booted from the clone. then i ran out of time and had to abort....uuuuh what a shit technician i am
                      • japlytic
                        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                        by japlytic
                        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                        Tried (only with keyboard/mouse connected):
                        • BIOS + database update
                        • Using latest Windows 11 image built with official image creation tool
                        • Previous setup version for Windows 11 installer
                        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                        06-19-2025, 04:59 PM
                        APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                        by sam_sam_sam
                        This started a few days ago and does this about every 8 hours
                        After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                        The battery backup is about 3 or 4 years old
                        Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                        06-02-2024, 02:30 AM
                      • Chris_stand
                        Clevo PD50PNN won't boot after BIOS Backup
                        by Chris_stand
                        i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                        At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                        Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                        But the...
                        04-28-2023, 03:08 PM
                      • intelg
                        HP Elitedesk 800 G6 lost BIOS admin password
                        by intelg
                        Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                        Here is the hardware identification specs:
                        HP EliteDesk 800 G6 Desktop Mini PC
                        Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                        BIOS ver S21 Ver. 02.05.01 01/05/2021
                        Born on date: 07/26/2021
                        SN MXL11841GN
                        SKU 3X8V9UCHABA
                        UUID 8116E79EF6FFE94DB0B98A3188270C5C
                        SYSTEM BOARD ID 8710
                        SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                        11-03-2023, 02:05 AM
                      • DiddiAb
                        BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                        by DiddiAb
                        Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                        I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                        03-11-2023, 03:15 AM
