usb firmware help
  • yonu
    • Nov 2007
    • 138
    usb firmware help
    question for you guys I have 7 generic usb sounds cards all the same model that are part of my home automation system however I am tired of the randomly getting out of order on reboots what I would like to do it is pull the firmware from one of them and rename each one what I am having trouble finding is a firmware dumping program that will do it. I am hoping someone here can help me out.
    Thanks,
    yonu
  • NxB
    • Feb 2009
    • 1595
    not enough info
    You want to change their HW id's? Can you manually set the resources so they are always in the same order? How does this work with home automation? Who makes these?
    • yonu
      • Nov 2007
      • 138
      Re: usb firmware help
      I have treyed changed resources hell they are even on 2 powered hubs but that hasn't helped. in the home automation they serve as the mic ports so that it can tell where the voice control is coming from and also as the speaker ports for each rooms voice commands and separate audio zones I have no idea who makes them I picked them up on ebay about 4 months ago for like 1.50 each shipped the only markings on them is a label with model hy554 usb 3D sound. windows simply sees them as a usb audio device in device manager and as sss usb headphone set everywhere else and from what I can find by google the sss usb headphone set comes from the device firmware. So I figure the best solution is to change what is in the firmware.
      • NxB
        • Feb 2009
        • 1595
        Things like this have poor software support. If there is no firmware update from the manufacturer then you are going to have serious problems. Crack one open and see what chip they use. Maybe there is a generic or reference design with firmware updates for it. You are trying to reverse engineer a piece of hardware that you don't even know the maker of. Just a thought; you might be able to differentiate them somehow under linux.
        • yonu
          • Nov 2007
          • 138
          will have to check the chip and nope have tryed it in windows liux and macos they all read as sss usb headphone set
          • yonu
            • Nov 2007
            • 138
            I was unable to find anything on the chip that identified a manufacture so here is a pic of the chip if anyone can help me out.
            Thanks,
            yonu
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              The chip marks aren't useful: the only reference is a post on the NSLU2 Linux wiki for a sound server mod. One guy bought an usb sound card with the same chip and managed to hear only heavily distorted sounds; attempts to find the manifacturer were unsuccesfull and he links a picture where the chip is claimed to be a fake.
              After the fake Kingston pen drives scam, our beloved chinese crap manifacturers are moving to counterfeit usb audio chips?
              Anyway post the USB ID (just read it with "lsusb -a" on a linux console or under Device manager on Winows): unless it's fake too, you can know at least the manifacturer.
              Zandrax
              Have an happy life.
              • yonu
                • Nov 2007
                • 138
                it actually has 2 ids one on the hid side and one on the audio side
                Hardware ID HID\Vid_0c76&Pid_1605&Rev_0100&MI_03
                Hardware ID USB\Vid_0c76&Pid_1605&Rev_0100&MI_00
                Thanks again
                also the audio I get from them is as good as my Soundblaster live outputs
                • NxB
                  • Feb 2009
                  • 1595
                  Finding squat on the ids. I think you're going to write an app to keep them in order. A lot easier than rewriting their firmware unless you physically access the chips. There may not be a software way to flash them.
                  You can try to find what chip they are copying and any documentation on that. I can't see any memory on that device, any flash or eeprom on the back? It might be all in one and not writable.
                  • yonu
                    • Nov 2007
                    • 138
                    nope the onley think on the back is a screen that says audio 008 and thanks was worth a shot
                    • kikkoman
                      • Jul 2007
                      • 691
                      that VID points to JMTek, one of those HUGE OEM manufacturers.
                      i'd say if that chip is a knockoff, it's probably designed after a C-Media chip (CM10x).
                      but even with those you wouldn't have much luck with the firmware thing.
                      maybe you can find a workaround... i.e. some device that connects them in a specific sequence after the os has loaded, with some pause in between.
                      you only need 2 lines per device (D+, D-) so this could even be done with relays.
                      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • TheUser
                        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                        by TheUser
                        Hello to everyone ,
                        This is my first post here, and i would like to share with you a small story in case you can help me.
                        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                        02-10-2024, 02:07 PM
                      • gurj1979
                        Ubiquiti firmware help. US-8-150W POE
                        by gurj1979
                        Hi guys.
                        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                        Got New chip and writes good.
                        THE PROBLEM...
                        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                        Does anyone have a Good Firmware I can have?...
                        07-22-2024, 05:13 PM
                      • Slapito
                        Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                        by Slapito
                        I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                        Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                        I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                        I already downloaded the BIOS update file from msi official...
                        Yesterday, 02:00 AM
                      • wattage
                        AOC AG493UCX 49-inch monitor - Firmware request
                        by wattage
                        Hello Badcaps Community,
                        The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                        07-13-2025, 04:41 PM
