C3420 transistor: possible replacements
  • rattlesnake
    • Dec 2017
    • 78
    • Argentina
    I found this datasheet, and even if my transistor doesn't have the "2S" written on it, I guess this is the correct datasheet, right? This is also relevant info.
    I was testing an old M919 v3.2 motherboard and doing something I shouldn't have done I damaged the C3420 transistor. Apparently (I'm a noob in electronics) it controls the voltage that is supplied to the CPU. In this case, the damaged C3420 will work with 5v CPUs but not with 3.3v CPUs.
    I had an exact same board laying around and replaced the bad transistor with an identical one and bingo, I was right, that was the problem! 3.3v CPUs work again with this one.
    Now the question is, what are possible, readily available replacements for this transistor?
    I also have a third M919 a-ok that doesn't have the C3420 transistor, but instead it has a couple of D882-0 transistors (if that info helps).
  • alindumitru46
    • Aug 2015
    • 255
    Re: C3420 transistor: possible replacements
    I think you have an very old PCChips motherboard, but you must upload some hi resolutions photos.
    A photo makes more than 1001 words
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      Don't know what sources you have available.
      You could try a MJE200, not a perfect match but might work.
      D882 is a bit weak but may work too...
      • DrFalken
        Dell Latitude 5530: damaged USB (type A) ports, cannot find replacements
        by DrFalken
        Yesterday a customer brought us a Latitude 5530 with 2 damaged USB ports (type A).
        The ports are made by Singatron and, checking the measurements and soldering points, the model should be this one: https://www.singatron.com.tw/en/product/file/280177-1
        I checked at RS, TME, Farnell but I didn't find this model
        Where can I find them? Something compatible is also fine...
        Thanks!!​
        10-19-2024, 01:43 AM
      • XxMicroSoldering
        ASUS Rog Strix G17-712LV Laptop Liquid damaged
        by XxMicroSoldering
        Hello Guys
        I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
        10-17-2024, 10:45 AM
      • ugamazing
        Procedural question about BGA rework and removal of CPUs
        by ugamazing
        I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
        I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
        I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
        07-12-2022, 03:11 PM
      • magneh
        Behringer Eurolive B205D repair - help identifying transistor
        by magneh
        Hello
        Got this speaker from a friend , defective. Power led comes on and off , in a loop.
        Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
        After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
        I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
        Still, I need to replace this transistor....
        06-18-2025, 02:34 AM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
