Tempered Glass Computer cases... sexy or sh*t?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Went looking at Canada Computers today... just looking, of course (anybody that knows me knows I never pay brick-and-mortar pricing on things).
    It seems that a new trend in cases is tempered glass with no external drives at all. I saw a few this way, but the inwin 805 stood out to me the most:
    https://www.in-win.com/en/gaming-chassis/805
    At $200ish CAD, I'm not in the market... but I will admit that's a sexy case.
    Even better, even though it's not advertized as EATX, from seeing it in person it looks like such would fit... . They say the max size GPU supported is 320mm, EATX is 330mm (so it would be a tight squeeze). It's certainly no full tower supermicro case, but with a few extra holes drilled and tapped one could make a very pretty workstation.
    What sucks is that the glass is heavy and fragile... not a LAN party case, obviously.
    What do you all think? Slick or shit?
    sigpic
    (Insert witty quote here)
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Tempered Glass Computer cases... sexy or sh*t?
    Shit. Then again, i like to sleeper my PCs. Old beige cases with modern high end internals.
    Follow the white rabbit.
      • 31200
      not a good idea if you like radio or have a HAM nearby!!
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ That too. PCs really don't like 6m or 40m. I know about 6m from experience. It killed the BMC on perfectly good Lenovo T520 battery. 40m is just general knowledge.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Not bad looking....but besides the above, can you imagine the filth that would show?!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • dmill89
            • Dec 2011
            • 2534
            ^This, they look good when new but are a giant pain to keep clean and will show every smudge and spec of dust. Of course there are the potential EMI issues stj mentioned, and since it is tempered glass it can be very fragile if you hit/bump it "wrong" (on an edge).
            • Topcat
              Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
              by Topcat
              Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
              Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
              09-29-2024, 03:55 PM
              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
              Securing a good thermal interface between...
              10-07-2024, 04:35 AM
            • tongshadow
              Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
              by tongshadow
              I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
              "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
              Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
              03-12-2023, 12:06 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • SarcasticOP
              Replaced the glass IC on a Series X, Pin 13 in now OL.
              by SarcasticOP
              Hello!
              I am replacing the booster IC (glass IC on the other side of the HDMI port) and I had to use a bypass chip I from Sourcely. I got everything set up and resolved the issue I was having from that (different line was OL) but now I am contending with this one. Is there something I can do to restore the signal?
              Attached is a photo with the pad in question that is supposed to supply the signal to pin 13 on the HDMI port. Tweezers where I am pointing to.
              12-18-2024, 02:29 PM
