Homemade Uniden CB antenna replacement
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I have a Uniden handheld CB that's missing an antenna and battery pack. The battery pack is not too big a deal because it also has a standard coaxial power receptacle.
    The antenna is annoying. While it also has an RCA phono jack, using it is unwieldy.
    Now it does have a 5/16" (~8mm) NEF thread (32TPI or ~0.8mm thread pitch) screw mount for an attached antenna. Anyone have ideas of what I could snag that would mesh with this, so it wouldn't be necessary to rethread it?
    (Hmm... I just thought of something, the standard Schrader valve could possibly be the right threadding... might have to look into finding a dead one and gutting that.)
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: Homemade Uniden CB antenna replacement
    I might guesing what you mean. Could you post a picture of a socket? Mini-UHF might be close.
    Laptops and computers repair.
      • 31066
      cant you change it to sma or bnc?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        No, that would defeat the purpose, would like for it to be directly attached to the radio. I think I have a couple of those RCA phono plug to BNC adapters, but having an antenna sticking out the bottom isn't quite right.
        Here's the threaded receiver. I suppose this is "HF" - shorter wavelength than shortwave but longer than VHF.
        • R_J
          • 9551
          Have you tried using the model number to look up a replacement antenna?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            And that would be homemade?
            • R_J
              • 9551
              No. sorry Thought if I saw an original antenna it might give an idea of what could be home made
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I wasn't able to find any detailed pictures of the original antenna - though I've seen some antennas that were meant for VHF frequencies that might screw into that mount.
                I figure that I will have to have some sort of ballast in the antenna as well. Unfortunately no SWR meter to tweak it. I wonder if I can use an oscilloscope (I should!) in lieu of a SWR meter...
                • R_J
                  • 9551
                  The optimal antenna length (1/4 wavelength) for the cb frequencies is 108 inches, not very practical for a handheld, so it would need some sort of loading coil to have it shorter and still be efficient. I remember the RadioShack handhelds used a telescopic center load antenna. The did have a short rubber (about 10") antenna available, I think the whole length was a coil
                  Not sure if this is any help.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I was planning to wind 9 ft of kynar 30 gauge wire onto some form, but the main issue is finding something that screws into the base... then need to attach the form to the base.
                    Best idea I can think of now is an old Schrader valve, anyone can think of something else that can be screwed in; then I can glue a form to that, and wind the wire onto the form.
                      • 31066
                      big balun wip, what is your CB band? 27MHz???
                      • R_J
                        • 9551
                        I have a Schrader valve and found a nut used to secure a control (pot) that threads on.
                        maybe the threaded section of a pot (brass) would work?
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Yes, CB is 27MHz (11m).
                          I thought standard pots were 3/8"? I grabbed a nut off of one of them and tried to mesh it against one of my car's tires (which I believe is the correct 5/16" 32TPI) and alas it's too big. The hole is visibly bigger than the receptacle in the radio. Was there also a standard 5/16" pot? Might be a mini pot or something which I don't have any of as far as I know; I'd have to sacrifice it too...
                          • R_J
                            • 9551
                            I'm not 100% sure if it is from a pot, switch or jack, I have a few in the shaft nut drawer
                            If a Schrader valve fits that might be the easiest, that seems to be a unique thread
                            That picture looks like it is a much coarser thread
                              • 31066
                              hold on, if it's japanese the thread will be metric.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                It quite possibly could be metric indeed. However it seems to mesh with 32tpi SAE thread feeler and both NF and NC (28 and 24 TPI respectively) do not mesh. A 6-32 screw meshes fine too, at least it looks like it holds flat against the wall as far as I can see.
                                I found that my air compressor screw-on blow gun nozzle tip will thread into this thing. And a Schrader valve cap will thread onto the blow gun nozzle!
                                I wonder if there are any other common things that will thread onto a Schrader valve cap?
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  can you not find someone with a lathe to make a fitting for you ? or in true diy style make it yourself on said lathe ? . sorry but i suppose i am lucky with access to such tools. a die nut might even work here .
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Well, the other possibility is buying a die to thread out a piece of 5/16" rod, which probably is easier to access to than a fairly complicated lathe that can accurately cut out the threads (it would need to be electronically done, so this would be quite an expensive machine!)
                                    I was hoping not to buy a die as this is a one-time deal, I doubt I'd need to cut another one I hope. The die probably would cost more than a Schrader valve
                                    (also as an afterthought, a piece of steel rod is probably more resistive than a Schrader valve which are usually made of ... brass? Hmmm.)
                                    • brispuss
                                      Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                                      by brispuss
                                      Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                                      Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                                      I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                                      12-28-2022, 02:58 AM
                                    • Hondaman
                                      Single-channel antenna?
                                      by Hondaman
                                      Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
                                      I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
                                      Years ago I made a "T"...
                                      11-18-2024, 01:14 AM
                                      MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                                      This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                      Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A315-58-38H7 + Pack Gold Acer 15.6'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-58-38H7 + Pack Gold Acer 15.6'' boardview and A315-58-38H7 + Pack Gold Acer 15.6'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 03:10 AM
