LED replacement for CCFL in PC monitors?
  • freedomlives
    • 11
    • Slovakia
    I've seen some kits on eBay from China that replace the CCFL tubes along the sides of the LCD with strips of white LEDs, and it comes with some controller and unclear directions about how its going to interface with the display.
    Anyone ever had any luck with these? They are around $5, and it looks like you cut the strip to the length you need, so I'm tempted to order one, in case any of my second hand monitors totally fry the CCFLs, or if I come across an LCD with bad backlight from someone.
    • 31294
    Re: LED replacement for CCFL in PC monitors?
    if you cut the strip it wont work.
    you buy the size you need.
    do a forum search.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      https://www.badcaps.net/forum/showth...light=ccfl+led
      https://www.youtube.com/watch?v=smrMoIpvYTk
      • freedomlives
        • 11
        • Slovakia
        Thanks. I guess typical ambigous ebay offer from China. Seller didn't seem to know anything when I asked them about it either.
        • diif
          • Feb 2014
          • 6978
          • England
          There seems to be a variety of fixed length ones on Ali and also universal, 54cm with the LEDs trimable in multiples of 3 and cover 15"-24" monitors.
          https://www.aliexpress.com/item/Univ...ing/1719601178
            • 31294
            go fixed-length.
            if you trim, a big one then you increase the current to the remaining leds.
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              Originally posted by stj
              go fixed-length.
              That depends on how the "controller" is designed. If the lamps are wired in series and the controller is just a constant (or "user adjustable variable") current source, then it won't matter.
              [Though removing too many from the string would increase Pd in the controller]
                • 31294
                well they arent, they are wired in parallel groups.
                these invertors dont step the voltage up much.
                • JPin818
                  • Aug 2018
                  Ive bought a couple of those ccfl to led kits off ebay, and replaced my monitors over the years. They work great, except once in a while the kit might be defective with not lighting up all the leds on a strip (quick contact seller and they send a new kit) other than that hit or miss its a great solution. YOU CAN CUT THE STRIPS TO FIT THE SIZE OF THE MONITOR, they are wired in parrallel groups of 3 leds in sequence and 3 leds is exactly 1 inch in length. So if you bought a 24 inch kit (540mm) u can cut down to 23, 22, 21, and i believe 20 or 19 is the minimum size down of length. So cut off in sets of 3
                    • 31294
                    if you get one that doesnt work, check the polarity of the leds,
                    i had one with the red & black the wrong way around.
                    i just swapped the contacts over in the plug shell to fix it.
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • ttmi100x
                      HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                      by ttmi100x
                      Greetings everyone,
                      I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                      The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                      Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                      Upon closer inspection...
                      07-31-2024, 06:36 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • adelage
                      220v Led strip flickering
                      by adelage
                      Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                      I know that the best solution would be to get a voltage...
                      11-03-2024, 09:49 AM
                    • mikey5791
                      Help on Samsung Syncmaster T220 dead ccfl lamp
                      by mikey5791
                      This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                      Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                      10-18-2020, 03:17 AM
