How not to be burned by new Android devices
  • japlytic
    • Oct 2005
    • 2086
    Here are the two basics:
    • Look for a commitment from the manufacturer to provide firmware updates for a reasonable time after the device model is discontinued - avoid devices which are not offered with firmware updates from the manufacturer.
    • Also, look for devices which use the Google Play store (and optionally, the manufacturer's and/or a third-party store) - also, avoid devices which don't.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: How not to be burned by new Android devices
    Custom rom like lineageos can provide security updates for devices that might have been abandoned by the manufacturer.
    Major manufacturers like Samsung, Google, etc are big enough and have enough marketshare that might get custom rom support.
    I buy used tablets, but only ones that have custom rom support with the latest security patches.
    --- begin sig file ---
    --- end sig file ---
      • 30985
      none of the bastards give long support.
      a better thing to look for is abillity to unlock the bootloader.
      either directly assisted like HTC and XAIOMI, or just by luck.
      because that way, you arent limited to the manufacturer for firmware updates.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        • Romania
        Doesn't Huawei support bootloader unlocking too?
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
          • 30985
          maybe, i have no experience with those.
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            ^Motorola does if you don't buy a carrier device. (really, just don't buy carrier branded and castrated anything...)
            Follow the white rabbit.
            • sabriTech07
              Acer B3-A30 Firmware - RV02RC07 WW GEN1 (Android 6)
              by sabriTech07
              I'm looking for the official stock firmware for the Acer Iconia One 10 B3-A30 tablet with the following version:
              • Firmware version: RV02RC07
              • Region: WW GEN1 (WorldWide)
              • Chipset: MediaTek MT8163
              • Android version: 6.0
              I've searched various sites but couldn't find this exact version. If anyone has a working download link or can share the firmware, I'd really appreciate it.
              Thank you in advance!
              05-15-2025, 05:52 AM
            • mon2
              Hisense 55Q9G Android reset / factory firmware reload
              by mon2
              Hello. Have a 55" Hisense TV that starts to load the Android OS (no backlight issues) -> reaches the app screen where you can view the assorted icons including Netflix and always crashes at the same point just after this launch. If I quickly press the cursor buttons, the cursor can navigate to the settings menu but will power off just after a few seconds of this activity. Do not believe it is power related since the crash is very accurate in the boot cycle.
              After the OS 'crashes', the power does go off and the from white LED goes dark for about 20 seconds and then ON again....
              01-03-2024, 10:25 AM
            • jczarniak
              JVC Fire TV or any other Android based firmware
              by jczarniak
              Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
              I have got JVC LT-50CF810 Fire TV with firmware not working properly.
              Thank you very much for any support.
              Regards.
              10-18-2023, 01:43 AM
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
