Things were a little slow today, so I puttered with this a little more. I figured before I went any further with the LED goofiness, I better do the IO plate area....if I screwed this up, the build is ruined/scrapped....so here we go, fingers crossed!
Measured & marked from the corners and lines masked off.
....and rough cut....
test fitted with some random mATX board & IO shield.
Motherboard tray standoffs lined up perfect (yea, I'm that good)!!!
Just for Momaka; properly deburred and edges cleaned!!
3 standoffs that need to be removed...
Now testing the fitment of the 'real mccoy'.... So far so good!
Things will be packed in here tight.....but FWIW, the case breathes well with 2x 120mm fans.
Next is CPU heatsink/fan fitment......I have a set of beefy copper monstrosities here somewhere, height clearances with the PSU cage will be the kryptonite. If they don't fit, I'll have to see if I can find some 1U Dynatron sinks for it that I'm positive will clear.....but until then....
