CPU Life Expectancy
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: CPU Life Expectancy
    Yea, I should add that I agree that CPU's don't die of old age (if it wasn't clear by my post)
    CPU's die of power spikes and ripple current
    But usually the power circuit on the mobo dies before that happens anyway!
    i4004; Ya, NASA uses them because their stuff does not require more power
    But problem is even if they wanted more processing power it would be difficult (without a specialized design)
    The small transistors of current CPU's have a problem in space; they are too suspectible to the noise caused by the sun in the form of electromagnetic radiation
    The stuff used in space is 250nm or larger (250nm is AFAIK cutting edge)
    What sits in my system right now is a 45nm CPU, quite the difference!
    Stuff is space also have other materials to protect it
    many of the cpu's spec'ed for space are radiation hardened too.
    r&d to do that is costly so just use more of the old,slow but PROVEN tech.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Originally posted by PCBONEZ
      I'm 6'3" and those damned suits never fit right.
      Stand up too fast in one and my testicles get to say hi to my tonsils.
      made for tiny japanese dudes.
      i cant even get into one of those suits.
      tried at hamvention one year where some used ones were on display.
      if it could have been zipped up it would have split as soon as i moved.
      not made for big uglys.
      • sLowEnd
        • Aug 2008
        • 33
        I've never seen a CPU run on stock voltage throughout it's life die
        In fact, I still have a few working Pentium 1's around
        • kikkoman
          • Jul 2007
          • 691
          now if thermal cycles have an impact on a cpu (which i think is a valid point), wouldn't SpeedStep or CnQ at least potentially lead to a reduced life expectancy?
          i've noticed that my CPU's internal temp sensors (it's an AMD X2, CnQ via RMClock) register rather big temperature changes when going from idle to full load.
          RMclock's monitor shows steps as big as ~3-5°C/sec.
          i'm not really surprised by these jumps since my CPU idles at 1.0 ghz@1.10V and goes to 3.1ghz@1.35V under full load (with intermediate steps) but i'm wondering if these hard transitions could noticeably reduce its life expectancy. (to be more precise, if this could kill the CPU faster than just running at full speed.)
          also wondering if this could overly stress the VRM (and PSU).
          "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            Thats why I turned cool 'n' quiet off of my 5000+, use to run at 1ghz at idle, and get back up to 2.6ghz when it was needed. Now it just runs at 2.6.
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              #26
              @ kikko:
              I experienced the same behavior with an old notebook equipped with a Mobile Athlon XP 2800+: temp spiked as the vcore rised, setting the same vcore on all multipliers lead to a slower variation.
              I don't know if the thermal diode is correct or is affected by vcore nor if the thermal cycles can noticeably affect life expectancy; however I wouldn't disable C&Q or Speedstep on a notebook since most small heatsinks aren't usually designed to cope with an always loaded processor (dissipation is one aspect where manifacturers cut corners and usually fans are bios controlled: you can't set fan speed) and I wouldn't disable on a desktop either since dissipated power depends linearly on vcore and more heat means higher power draw and faster/noisier fans: main exception is to set a fixed multiplier both for overclocking and underclocking.
              Zandrax
              Have an happy life.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Thermal cycles have a negative effect.
                Heat has a negative effect.
                Which one is the bigger negative? - I dunno. That's COMPLICATED.
                The duty cycles (how long it's left hot and how hot) vs (how often/far it's thermal cycled) would play a big part in the math for that.
                I used to do similar calculations for fuel cell materials and even just bolts used in reactor cores as part on my job. It's quite complicated because even such things as how pure the metals/materials are comes into play. Impurities cause stress cracks in materials during thermal cycles and impurities can be 'acquired' over a components lifetime by physical contact with other materials. [This is one of the problems we had to deal with: http://en.wikipedia.org/wiki/Hydrogen_embrittlement - for us the hydrogen came from random 'free' hydrogen atoms natural in water which is used for coolant.]
                Similar situations exist for silicon materials used in IC chips but I've never actually had to do the math for that sort of thing.
                The basic idea is you test/analyze every part.
                [In a CPU that would include each PN type junction (several per transistor) and each connection to the PN material (the connections that end up as pins outside the package) and any place where materials are bonded/formed onto the substrate.]
                You find what's called "the Most Limiting Component" and base the rating for the whole chip on that.
                The Most Limiting Components for heat-up, cool down, fast thermal cycles, slow thermal cycles, and prolonged heat exposure may be completely different parts. Also their effects aren't linear. [Heat-up from say 70F to 80F may be 1/10 as bad as heat-up from 80F to 90F.]
                So, I dunno a solid answer, just the theory.
                I'd have to say though that Speed-Step kicking in like every 1/2 minutes is [in materials theory] a lot worse for the CPU than it kicking in once every 10/20 minutes or so.
                Mann-Made Global Warming.
                - Dr Seuss
                • gdement
                  • Jan 2007
                  • 690
                  #28
                  Originally posted by zandrax
                  @ kikko:
                  I think I encountered that on my brother's HP laptop. We installed some memory in it, and I immediately had him run memtest86. After about 10 minutes the laptop suddenly turned off. I guess it overheated.
                  It's odd though, he said that's never happened with the long video rendering jobs he does on his laptop routinely. Seems that would hit the CPU just as hard and those jobs can take hours.
                  • tazwegion
                    • Jun 2006
                    • 444
                    Yeah I agree, our firewall system is running on a Cyrix 233MX flawlessly
                    Heat, Power irregularities & User abuse (overclocking) are the general causes of processor death IMHO
                    Viva LA Retro!
                    • slybunda
                      Picking long life capacitor replacements?
                      by slybunda
                      to pick some good quality capacitors for long lifetime do i just go to mouser, rs etc and select the capacitance and voltage then sort by the highest number of hours and pick the caps that have the highest number of lifetime hours?
                      02-08-2024, 03:56 AM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • someonenotyou
                      Dell Vostro 3501 - no signs of life after BIOS read
                      by someonenotyou
                      Hi.
                      I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                      Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                      After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                      Then I took the motherboard out...
                      01-27-2025, 05:15 AM
                    • szreder6
                      HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                      by szreder6
                      Hello guys,
                      I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                      What I did:
                      - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                      As far as I know the laptop was in another service center...
                      11-22-2024, 05:17 PM
                    • ArtMov
                      [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                      by ArtMov
                      Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                      1. I made overclocking lock disabled the default in amibcp
                      2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                      03-31-2023, 01:30 PM
