The (now the death of) Dolby DP600 Build (BEYOND COOL BUT PIC HEAVY)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Another little finishing touch.....labels for the controls & lights. This isn't realy how I wanted to do it; the original plan was vinyls with my wife's cricut.....but that wasn't working at all with letters so small....so I ended up using the label maker. Yes, after a couple years, I know what everything is for.....but it just looked incomplete without some kind of labeling....so here it is.
    Now you know what all the lights are for.....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • Jul 2011
      • 6069
      This is the most professional thing I have seen in very long time with put together parts and I can see from the hour meter that you use it quite a bit and if you have been following my ZD-987 switching power supply modifications
      I personally think that you did a very good job and made it look very professional and very functional at the same time
      I get some of inspiration from this post and what you have done here to solve a monitoring the computer system voltage and current and see if things are the way they should be of course my situation is a little bit different in the respect of I was having switching power supply failure after many hours of use and need a solution for this issue of mine because too buy another dual desoldering/soldering station is not cheap over $250.00 plus shipping and a month of waiting time unless I can find a seller in the USA which is not easy and more often than that it is more expensive than buying it from China
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        2000 hour update....well close enough...
        Nothing to really report; no problems or revisions.....but I did have a board in it creating one hell of a load!! X9DAI with a pair of E5-2667 V2's @ 3.3GHz 8C 16T 130W CPU's with 512GB RAM. Memtesting had it pulling nicely on the 12V rail.....
        ...and that's just memtest... It kept the room warm!!
        Team : 49813
        Join in!!
        Team Stats
          • Jul 2011
          • 6069
          How did you make it so you could monitor the amperage of the PCIe slots that is interesting
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            It monitors PCIe power; IE a GPU's PCIe EXT power connector.
            Team : 49813
            Join in!!
            Team Stats
              • Jul 2011
              • 6069
              Thanks for sharing this and clarifying how you did this
              And yes I do still follow your post about your test machine and the results that you have provided in your post about the motherboard that you tested
