Cheap Source for Racks?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Cheap Source for Racks?
    Crap. try 2's real link:
    http://www.ebay.com/itm/292223781061...N101.S1.R1.TR4
    sigpic
    (Insert witty quote here)
    • diif
      • Feb 2014
      • 6978
      • England
      #42
      That switch supports link aggregation, your unamanaged switches do not.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        And I take it that the managed switch couldn't use the same round-robin bonding (link aggregation) technique that my server uses without issue?
        sigpic
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          #44
          Saw this:
          http://www.ebay.com/itm/Cisco-SGE201...4AAOSw7pNZnYVX
          But nah, probably unrepairable junk?
          Switches tend to be difficult to repair. They are relatively highly integrated implementations -- unless a connector (or power supply) is broken, you'll probably find you've just wasted a lot of time on some scrap metal.
          Reason I ask is I just scored some dirt cheap quad port gigabit cards and thinking that 24 ports isn't going to cut it. Or not and I get a 16 port switch for the office and give it 4 links (So I can quad team my workstation and dual team my wife's workstation, but neither of us will need all the bandwidth at the same time?
          Think carefully about how you plan on using each "drop", regardless of its physical location. If I need a horrendously fat pipe, its typically only for a very short duration/special purpose need. E.g., making a copy of a 4T disk. In those cases, there are usually other options that are simpler and more reliable (e.g., physically move the drive to be co-hosted with its twin and do the transfer at ~6Gb speeds)
          Within my office, Gb links are more than adequate. Anything outside the office can be throttled to 100Mb and still be "tickled" with the available bandwidth. I'll be running fiber out to the shed -- but that's mainly for protection from lightning, etc.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            See other posts...
            sigpic
            • diif
              • Feb 2014
              • 6978
              • England
              #46
              Not without both of the switches supporting it....deja vu ?
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                But clearly the gigabit switches (which are the same model) accept such connections from servers and the like. Right now I'm running a 3 connection round robin bond to one of said switches from my server and everything works just fine. Topcat has the exact same model too and he's had no issues. Is that sufficient enough proof?
                sigpic
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #48
                  Whats TC doing ? link aggregation from one managed switch to an unmanaged switch ?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Server to switch.
                    Is there something fundamentally different about PC aggregated connections and managed switch aggregated connections?
                    sigpic
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      #50
                      Server to switch.
                      Yes. Linux bonding code does not restrict bonds to the LACP/802.3ad mode of operation. The Linux box is stopping the loopback on the unmanaged switch.
                      Switches need to adhere to those standards mentioned for link aggregation to work. The managed switch can not stop the loopback.
                      There's a reason network guys are paid far more than sysadmins. Routing packets properly is not my idea of fun so I only know enough to get me by, but it's not hard to do a search online to see if I'm talking horseshit or not.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        OK!!!
                        I get what you're saying. I'll go with the 2+2+1 option for the office then; two workstations with 2gbs bonds, and 1 to the 24 port switch for everything else. Assuming I can make teaming work on an nvidia Nforce Pro 2000 series Glans on windows 7 do teaming. If not, then maybe 2+1... once the switch gets here I plan to use it to set up bonding/teaming on the two office workstations as a test.
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          No bueno on either system teaming. V5's LAN quit working (again, when it was working it was unstable as shit), likely a fried chip. V3.8's Nvidia nForce Pro 2000 chips don't support teaming in windows 7 (and being my wife's rig, I don't dare put server 2012 on it). V4 and V2.5 both support it but aren't being used. The last system is an X5DAL-g with only one NIC.
                          Perhaps I just run 1 line initially to the office and run everything off the 24 port office switch, now installed in the back of my tower/cart (no good pics, sorry)
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Here's a picture:
                            Sure beats the plastic 5 Port Belkin switch I was using. Not that I'm tossing anything; for my future office having 23 connections will be handy (I'm thinking of putting in a table for laptop docks, for instance, that will eat a few...)
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Finally found a deal on Cat5e:
                              http://www.ebay.com/itm/Cat5e-enhanc...kAAOSwFe5X0Br4
                              $51 shipped for 1000' isn't too bad, right? Beats the $60-$80 I was seeing (for solid copper, not CCA wannabe shit). UTP isn't shielded (despite the claim of the seller), but it is solid copper, so still a deal.
                              sigpic
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16959
                                I dont remember what I paid for the last 1000' spool, but thats sounds close.
                                <--- Badcaps.net Founder
                                Badcaps.net Services:
                                Motherboard Repair Services
                                http://folding.stanford.edu/
                                Team : 49813
                                Join in!!
                                Team Stats
                                • bluto
                                  • Oct 2007
                                  • 560
                                  #56
                                  I wouldn't mess with any no-name cable from eBay if you plan to do a permanent installation. How can you be sure it is not CCA or actually manufactured to spec? Better to spend a couple extra $ for a reputable box of cable from the big box store to know you won't have to rip it out and re-do it later. If you still don't agree, read the article over on blue jeans cable about how they tested store bought patch cables with a Fluke and almost none passed as meeting Cat5e specs. As they also say, if you buy their expensive cables to install in your walls and later you have some kind of problem with your system.. You are assured that the cable is NOT the source of the problem.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    ^I'll do a cut check... since it was sold as new and does come out as CCA, I'll get a refund or something (as the seller lied or screwed up). Seems to be a reputable brand; they don't even sell CCA. Unless somebody reboxed some CCA shit, all signs point towards legit.
                                    Link to the OEM's listing: http://www.hosiwell.com/exec/product...at-5e-UTP&lg=E
                                    With the new house money is going to be a bit tight. I'd rather get it wired up before I have the house fully moved in. A penny saved is a penny earned. It might not be belden (or the like), but I think it will be fine.
                                    sigpic
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Wire came in. Appears to be legit based on weight and cut check. Brand new spool too. Appears to be really good quality.
                                      sigpic
                                      • shakyshee
                                        • Oct 2017
                                        • 3
                                        They don't have anything in their site that says racks, but since they offer metal machining services and other furniture of some sort, they can help you with cheap racks. Also, the said company, which offers metal machining services is China based, so if you're looking for cheap, they are the way to go.
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          ^ I already have a rack... did you read the thread?
                                          sigpic
                                            Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                                            by sam_sam_sam
                                            Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                                            I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                                            09-13-2024, 06:47 AM
                                          • Spork Schivago
                                            Identification of two round holes on top of rack.
                                            by Spork Schivago
                                            Hello!
                                            I've searched the internet, skimmed through a lot of HPE PDFs, all searching for the answer to a simple question. On the top of my HPE H6J77A Advanced Series rack (36U), there are two round holes on the front top of the rack. What are those holes for?
                                            Here is a picture of the holes that I'm talking about. I know what the square on the back is for.
                                            I originally thought fans, but no, the fan kit is for the middle of the top of the rack. Then I thought maybe duct work for cooling, but that doesn't make sense with both being on the top there. I looked...
                                            10-27-2018, 04:50 PM
                                          • slybunda
                                            Capacitor shelf life or expiry date?
                                            by slybunda
                                            do capacitors have a limited life even if just kept in a box in storage?
                                            11-20-2023, 02:23 AM
                                          • MeanStreets
                                            Ibanez Delay Rack Re-Cap
                                            by MeanStreets
                                            Hoping to get some insight on how best to go about overhauling this old Ibanez delay. Its from 1983 so it celebrates its 40th birthday this year, the unit still functions however i heard a high pitch oscillating whine from it a few weeks ago and decided to strip the chassis and have a look.
                                            It looks like the 25v and 16v caps are leaking, there have been a few replacement caps in its lifetime as it has some bi-polar caps installed that differ from the polarized ones in the unit.
                                            My plan was to swap out all of the electrolytic capacitors,...
                                            05-11-2023, 03:32 PM
                                          • 5mall5nail5
                                            Help identifying connector for ASUS 4090 Strix RGB LED connector
                                            by 5mall5nail5
                                            Hi All -
                                            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                                            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                                            05-04-2025, 07:47 AM
