Capacitor shelf life or expiry date?
  • slybunda
    • Feb 2012
    • 139
    do capacitors have a limited life even if just kept in a box in storage?
    • 31218
    Re: Capacitor shelf life or expiry date?
    only electrolytics - because they have liquid sealed in them
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      It may take years or decades, but as stj posted, electrolytics can dry out sitting on a shelf or in something electronic that is not powered on for those years.
      Electrolytics that are not used for quite a few months (a year or two?) can also have the aluminum oxide dielectric thin, so that they can no longer withstand their full rated voltage. This thread discusses the process of re-forming the dielectric layer, https://www.badcaps.net/forum/showthread.php?t=50530 .
      I apologize for being vague about timing, but electrolytic capacitors don't have a "Best If Used By" date.
      PeteS in CA
      • slybunda
        • Feb 2012
        • 139
        good info there to read up on. didnt realize caps could degrade when not used.
          • 31218
          the electrolyte is sealed in with a rubber bung - it can harden and degrade too.
          there have been attempts to improve this, but i dont know if they helped because i never see the capa i'm about to mention unused.
          an american company in the 80's put epoxy over the end of the cap to cover the rubber seal,
          the japanese made some with a plastic case and an epoxy seal instead of the rubber,
          and the soviets used a plastic bung with a rubber washer and crimped the can over it.
          what i can say is none of those ideas stop them aging inside stuff.
          so now you know more than you wanted to know
          • andrewsawesomr
            • Jun 2022
            • 101
            • United States of America
            The rule of thumb I've heard is to not store electrolytic capacitors for more than 5 years, but I'm not sure how true that is
            • PeteS in CA
              • Aug 2005
              • 3581
              I remember seeing some larger US-made caps with epoxy end seals (Sprague 676D and 677D? And Mallory's near-equivalent?). Nippon Chemicon's RZ and RZA series had epoxy end seals. But I only saw new parts of these types, not parts that had sat unused on a shelf for 10 years. I think that the fact that epoxy end seal parts are uncommon (some Vishay 678D parts are available with epoxy end seal) suggests that either it was ineffective or the cost-benefit ratio made it economically marginal.
              PeteS in CA
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • AleXis6
                Manufacturing Date of Electrolytic capacitor
                by AleXis6
                Guys. could you help me please to decode some codes of main capacitor's producers.
                I would like to know the manufacturing date.
                Based on the information from capacitors I have - it seems easy to decode manufacturing date for Rubycon, Nichicon.
                If I understood correctly:
                1. Nichicons marks date of production as (see the attached pictures) H2116
                I don't understand the meaning of first letter - may be it is code of factory.
                21 -year
                16 week
                I bought this capacitor recently.
                another one-
                2....
                10-11-2021, 02:20 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
