Help finding a resistor
  • Gimi
    • Aug 2015
    • 75
    Hi. Just need if possible for anyone to find this resistor PR801 where to get it from ? Thank you
    • 30917
    Re: Help finding a resistor
    everything you need is there.
    1206 is a package style,
    0.01ohms - very low that, it wont come cheap.
    1% tolerance
    D - ??? dont know that reference.
    what is it on? i may be able to get one from a scrap pcb
    • Gimi
      • Aug 2015
      • 75
      Hi. Thanks for the replay .it's from a dell e6230 motherboard
      • Gimi
        • Aug 2015
        • 75
        Hi. Would this eBay part number be correct:112368746577? Thank you
          • 30917
          maybe, i would try RS first.
          but before you do, what is wrong with the old one?
          these things dont fail - they are only killed by something else!
          • Gimi
            • Aug 2015
            • 75
            Got this from a friend to try repair. Is making a short , when battery and power supply both attached then power supply dies. Tested a few things and this shows the problem (hopping this is the one anyway lol). Thanks and will try rs.
              • 30917
              0.01ohms is supposed to look like a short!
              • mariushm
                • May 2011
                • 3799
                That's a current sense resistor... it has 4 terminals because two terminals are supposed to connect to the big traces carrying current and the 2 thinner traces are going to an opamp or something that would measure the voltage drop across the resistor.
                Here's some examples of such resistors:
                Depending on the circuit board footprint you probably could use plain 1206 resistors .. just make sure you get the ones with the proper orientation (terminals on the long side or the narrow side)
                Here's a start link for you in UK (also check http://cpc.farnell.com with smaller selection but selling as little as 1pcs of some parts and cheaper or free shipping in UK) : http://uk.farnell.com/c/passive-comp...6-3216-metric-
                Also ... make sure the resistor is actually bad, because you may confuse it for a short due to having so low resistance. Use the REL button on your meter to take out the resistance leads and then measure the resistor when it's desoldered from the board.
                It should measure 0.1 ohms.
                Later edit: You should also be able to squeeze 0805 resistors on the footprint, just may have to put a couple of blobs of solder on the pads to solder the smaller resistor well. Then you'd have a much wider selection.
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
