key logging
Re: key logging
Why wouldn't it affect other computers with Conexant audio chips? Was the file containing the keylogger customized for HP?
At least Windows has a generic driver for HD Audio devices. It even sounds better than the Conexant driver that was installed on my laptop.Last edited by lti; 05-13-2017, 07:44 PM. -
Re: key logging
Close. You know those "hp" printer "drivers" that are ~500+ MB? Sure, the actual driver's in there, but what about the ~480MB of other stuff?
Originally posted by stjonly on HP???
HP- meyer's fustercluck
"pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Re: key logging
The Conexant audio driver for my Toshiba laptop is 59.4MB. I remember the MaxxAudio "enhancement" software being two-thirds of that. That isn't as bloated as HP printer drivers, but it is unnecessarily large for an audio driver. The driver for the ESS ES1869 in my K6-2 system is less than 2MB, includes an "enhancement," and sounds better than anything from Conexant I've used.Comment
Re: key logging
The Conexant audio driver for my Toshiba laptop is 59.4MB. I remember the MaxxAudio "enhancement" software being two-thirds of that. That isn't as bloated as HP printer drivers, but it is unnecessarily large for an audio driver. The driver for the ESS ES1869 in my K6-2 system is less than 2MB, includes an "enhancement," and sounds better than anything from Conexant I've used.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
by osrexHello, this is my first post and im just a beginner, so be easy on me guy. thanks
i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
i have no datasheet at all for the LED lights, all i have is its length.
long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,... -
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by charifNeed Audio Driver for Thomson P14C4BK128 (Windows 10/11)
I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
Here are the details:- Model: Thomson P14C4BK128
- Operating System: Windows 10 64-bit
If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
Thanks in advance for your help!-
by bohabohaHello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encountered an error.
but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
any help?-
by DaveleoneHello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one... - Loading...
